Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
I have a bosch 6805uc dishwasher the display has two red dots in
I ran the diagnostic program and after a few minutes i get a 4 code. In addition the display also displays two periods one in front of the 4 and one after the 4. I believe that the 4 code is indicating a water level switch problem. The water switch is part of an assembly that has a blue plastic part that is pushed by a diaphragm . I have the machine out so i can see the switch assembly and the switch never gets closed. I can't see how the water flow can close the switch?
this is me
  • 48 Answers
SOURCE: Long cycle times
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. About the led: If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Posted on Jan 01, 2006
silly girl
  • 513 Answers
SOURCE: Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - Good luck!
Posted on Mar 26, 2006
  • 175 Answers
SOURCE: Bosch dishwasher SHU9922UC
Sounds like you already know how to fix it. The inlet valve is only held closed by water pressure...if you have low water pressure it could be causing this. Its more likely just a bad fill valve though. The water inlet valve is accessed by removinf the lower kickplate and the sheild behind that. Then all you have to do is remove the water line from the valve, remove the 2 screws holding it and pull it out far enough to disconnect the 2(possibly 3) wires and the fill hose. Make sure to mark where your wires go, if you hook it up wrong it could continue to fill and overflow. Hope this helps!
Posted on Feb 02, 2007
  • 213 Answers
SOURCE: Electronic controls don't count down properly
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Posted on Nov 20, 2007
  • 409 Answers
SOURCE: Bosch SHY56A Dishwasher
if the door doesn't shut, the push buttons should not work. that way you are not running your d/w with the door open. check the door latch, as it seems to be malfunctioning. if the d/w still does not work, replace the door latch.
Posted on Sep 13, 2008
Bosch dishwasher stopped working after few minutes. And LED displayed E:24. What is the problem?
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
Sep 05, 2016 | Bosch Dishwashers
How do I run a self diagnostic on Bosch Classic Electronic SGU53E75AU/86?
Before going to the controller it might be better to verify the heater or thermostat (NTC).
If you want to know the part details refer this schematic
It is interactive and you can switch between assembly drawings and parts lists. The heater and thermostat are drawing 4.
Apr 26, 2014 | Bosch Dishwashers
Shu43c diagnostic code retrieval
I believe you have found the code sequence as shown in your additional information post. Please clarify if you are looking for anything additional.
Apr 16, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher model shu43c05uc diagnostic code C1 at start then P0. what does this mean?
You seem to have inadvertently put it into the test sequence. Try pressing the two reset button simultaneously (usually the reset buttons are 1st and 3rd from left each with a dot underneath, if this does not work, press the button between the two resets (2nd button) P1 should come on then press the right reset button. The unit should run through a test cycle for approx 20mins and eventually reset the module, this is indicated by 0 in the display. Please repost if further assistance required.
Feb 28, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch SHU5316UC dishwasher. The last two times it ran, my wife says the display said "CL" (for clean) after running through the cycle, but she heard a "motor running" until...
P stands for program in computer algorthms. The device displays program whenver chages were made to the default settings. A powered on devices least has malfunction only requires reseting to attaon default features. Depending on the type of device, reset would be a button that is pressed held for an extensive duration to clear the entire corrupted data to make way for default. Refer to the device user guide also for further asssistance.
Feb 15, 2011 | Bosch SHU5316UC Dishwasher
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Squealing noise
The pump motor is beginning to seize up. You may be able to take the dishwasher apart and lubricate the bearings and keep it going for a while, but at some point you will likely have to replace the pump motor assembly.
Jul 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
125 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
