Question about Dryers
I HAVE AN AMANA HEAVY DUTY DRYER 9 CYCLES. IT RUNS BUT THERE IS NO HEAT TO DRY THE CLOTHES. THE PROBLEM JUST STARTED IT RAN GREAT BEFORE. I CLEANED LINT THAT WAS EXHAUSTING TO OUTSIDE. THERE REALLY WAS NOT MUCH OF A BUILD UP. IS THERE SOMETHING I CAN FIX MYSELF TO FIX THE PROBLEM? IS THERE A FEE FOR THIS? IF SO I WILL CALL SOME ONE TO LOOK AT IT THANK YOU.
    Genius:
  • 1,122 Answers
A power surge could have blown the heater fuse under the top lid on the back wall,that is also where the heating element is,you can unplug the dryer and check them both if you have a omns meter,if you can't call your local appliance repair man(not sears $85 to knock on your door)and you know what he is going to look for and can't rip you off,let me know how you make out-mike
Posted on Apr 16, 2009
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
My amana gas dryer seems to be taking longer then normal to dry clothes. I've always used the moisture sensor and one day I noticed it had been running for 10 hours (although the clothes were dry and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 21, 2011 | Dryers
It takes at least 2 cycles to dry clothes. It is Roper heavy duty high capacity electric dryer. Thank you for any help you can give me. janebellard@yahoo.com
Check for air restrictions which cause the heat control to shut down faster than normal.
When the moisture cannot be removed fast enough the heat builds up and has nowhere to go so the heat control stays off longer and the clothes just tumble on.
Service manual and more HERE
Mar 14, 2011 | Roper Dryers
Hello, I have Amana LG4309W heavy duty gas dryer.
sounds like one of the supply fuses at the house panel,these 240 volt dryers are wired so the timer is on one phase(120)volt and the motor is on the opposite phase(120)volt and the heating element is on both phases for a combined 240 volts,if you lose one phase you either wont get motor operation or timer operation,and for sure no heat and you have the timer so you have 120volts
Jan 08, 2011 | Amana Dryers
Dryer runs but no heat
lean the exhaust vent tubes thoroughly and try again to heat up
a sensor in your dryer will shut down the heat if lint build up is present
Jun 07, 2010 | Amana NDE2330AY Electric Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Gas dryer runs, cleaned hose, get warm does not heat up to dry
with a gas dryer in which your assured te hventing is free and clear of any obstructions, i would look to replace the coil pack located atop the gas valve itself, probably about $25 part number 279834... 2 coils simply mount atop the valvle
Feb 11, 2009 | Whirlpool Dryers
Dryers Logo
96 people viewed this question
Top Dryers Experts
