Question about Polaroid FLM-1517 15 in. LCD Television
Only see a blue screen ...
When the TV is turned on, we only see a blue screen. We can change between inputs (S Video, TV, etc.), but the screen is just solid blue at all times. The only thing that we ever see on this blue screen is the input mode (S Video,TV ...), the channel if we try to change channels, etc. In other words, we can see these types of things on the screen, but never see anything else (the the TV picture ...). What would cause this problem and what can be done to fix it? Thanks for your help.
  • 1 more comment
  • kyle petee Feb 27, 2008
    I have a mitsubishi big screen tv and when I power it up the screen just stay's blue and its not in the video mode. I would like to try to repair this problem my self.
  • Anonymous Feb 29, 2008
    blue screen only
  • Anonymous Apr 06, 2008
    Only a blue screen I changed channels on the tv all the way up channel 120 only to see a faint pivture on channel 116 which it was in black and white with no sound
    Brigadier General:
  • 6,966 Answers
Hi, The bluescreen is an indicator of "lack or absence of a video signal". In TV mode this would only come on if your reception quality is so poor that the TV "thinks" there is more interference/noise than intelligent video signal nd therefore mutes the video. In all other modes, (S Video, A/V Video etc), again, this muting action will result in the bluescreen if the TV "thinks" it is not receiving any video input. To try and fix this would either be: 1. Check and verify that you have a video signal coming into the TV by trying your video source (DVD, cable box) into another TV unit; or 2. Check and verify that your connectors at the back of the TV and the source are properly connected and are snug/fitted properly. If both fails, it is possible that you have component failure inside the TV and that would require the services of a qualified TV professional. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 15, 2007
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
My Toshiba TV shows blue screen an no signal
The TV may not be on the correct source or input.
You can change the source by pressing the source or input on the TV or remote. VIDEO 1, 2,3. COMPONENT 1,2 OR HDMI 1 etc..
www.aaatvservice.com
Aug 15, 2014 | Televison & Video
The power stand by light is on when i push the power button it stays red, the after a while of pushing the button it turnes green but all i get is a blue screen
YOU NEED TO CHANGE THE INPUT OF YOUR TELEVISION SET TO THE CORRECT SOURCE. FOR EXAMPLE: HDMI1, AUDIO VIDEO IN, YPBR INPUT ETC, YOU CAN DO THIS BY THE USE OF YOUR TV REMOTE.
Aug 14, 2013 | Apex Digital DT502
When the television is turned on it will then turn off
You more than likely have the TV on the wrong input. If your source(cable,VCR,DVD) are on input one then you will have to change the TV input settings to input one, or two or video 1, HDMI 1...etc.
Oct 05, 2012 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I have a apex 32-inch tv model (AT3208S), This tv was connect to a converter box, the other day electric power went out in our area for about 8 mins or less, once the power was back on the tv screen was...
OK, I have one of these TVs, and here's a thought: There's nothing wrong with the TV nor with the cable converter box. Please bear with me. Since I don't know how much you may know about TVs in general and this one in particular, I'm going to assume you know nothing and go from there.
This TV has several different "inputs", which are ways a signal can be transferred from its source to the TV, where it "outputs" the video image. I believe this particular TV has 5 different inputs: In descending order of the quality of the video signal, there're one S-video input (a 4-pin video connector plus red & white audio), three composite video inputs (3 connectors each: yellow video and red/white audio--audio connectors are the same for both s-video and composite), and one coax connector (a single large screw-on connector with a little wire sticking up through the center of it) for a total of five different inputs.
The problem with these Apex TVs is that they always default to the Antenna/coax input first when they are restarted. Most people use the TV to display an input signal (like the cable box or a DVD player) connected either to the S-video or to one of the 3 composite video inputs, not to the coax input, which just displays the channel numbers from 1-125 when it's set to do that (hit the "display" button on your remote to toggle showing the channel numbers for the coax input). If there's no signal coming into the coax input, the screen with appear blue. (If it's blue, it simply means it's not getting a signal via the input to which the TV is currently set. You can turn off the blue screen in the menu settings, but then you'll just get a blank screen. It's probably better just to leave the screen blue; at least you can tell the TV's actually trying to display something that way.)
You have to manually select the proper input by pressing the "video" button either on the remote (lower right corner) or the "video" button directly on the TV (hidden control panel under the middle of the margin around the bottom of the TV screen. You'll have to press on the door, and the whole control panel rolls open to reveal another set of composite inputs and some buttons. The video button is the one farthest to the left.)
Anyhow, by pressing the video buttons, you'll cycle through the various inputs. Assuming your cable converter box is functioning properly, powered on, receiving a signal from the cable company, and connected to the TV via a(n) appropriate wire(s) connected correctly, you should see the output from the cable box on the screen when you cycle through to display the proper video input.
Another possibility: the power outage fried the input to which your cable box was connected on the back of the TV. If that's the case, your cable box would probably also have sustained damage. You can check to see if the various video inputs on the TV are working by connecting different source inputs (like a BluRay/DVD/VCR player, video game console, video camera, etc.) to one of the other inputs and see if you get a picture when the TV is set to the appropriate inputs. (Remember, the "video" button is what selects/changes/cycles through the various video inputs.) One of the sets of inputs went bad on my TV. I just use the other ones.
May 18, 2011 | Televison & Video
Can not see the Video when I input it, see only a blue screen.
ok hook up the audio video in the OUTPUT on vcr and INPUT on the tv then make sure tv is changed to the right input channel now go to vcr and change that channel to AV,.if AV isnt there you may have to go into menu of vcr and do a channel search,but when you change it to AV on vcr you should see the picture
May 27, 2009 | Televison & Video
We have a blue screen, what do we need to do to get the TV back o
hit the input button on the remote,once or twice to get picture.or it may be labeled audio/video
May 09, 2009 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Blue screen, no video, but has sound
Did you hit the "input" or "video source" button by mistake on the remote or TV? That would change the input from the one the cable/video source uses. You're getting sound, so it's working......sounds as if the input was maybe changed. I'd hit the input/video source button a few times to go through all the available inputs and see if you get video back.
Dec 08, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
Polaroid FLM-1517 15 in. LCD Television Logo
442 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
