Printing is not clear on the right side of the printed paper. Even when a new ink cartridge is installed the printing is not very readable on the right side of the printed paper.
  • 2 more comments
  • davidcannonm Apr 15, 2009
    It is a Canon Super G3, Series MF 5700. The printing is clear (readable) on the rest of the page. On the right side of the printed page it is not very readable (too light).
    Yes, I can print to the machine. The same problem exists when printing to the machine as it does when copying.
  • Arthur Hoffmann
    Arthur Hoffmann May 11, 2010
    Can you print to the machine? if so, are your prints Light also?
  • Arthur Hoffmann
    What type of copy machine? Is the printing "clear" on the rest of the page?
    When you refer to "Clear" do you mean it is lighter then the rest of the page?
  • 227 Answers
Ok try this...... Somewhere around the toner bottle, should be a piece of glass covering the laser from getting toner in it, remove the glass and clean it. Let me know if this works.
Posted on Apr 15, 2009
Installed a new cartridge and no imaging is printing on photo paper
Sounds like Blocked Nozzle heads assuming its making the correct noises when press "print" If Not
First ensure connected correctly:
Control panel / Devices and printers / select printer ( make sure its the default printer) right click on printer properties : Print test page.
Next repeat but right click Printing Preferences / maintenance / Nozzle check then Head cleaning.
This generally works with printers used fairly regularly.
Where printers left for long periods may have to resort to removing offending cartridge/s and using a syringe with warm water and flexible tubing to clear blocked print head (gently !) Kitchen towel underneath the print head will show when ink / water is clear. Usually have to replace with new cartridges :Then use nozzle check.
May 14, 2016 | Epson PictureMate 500 InkJet Photo Printer
Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
Dec 24, 2012 | HP Photosmart 3210 Printer
Error E and 5
Number following "E"
Cause
How to correct
No paper. /
Paper does not feed.
If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Paper jam
Remove the jammed paper.
If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
Empty ink tank
An ink cartridge is empty.
To cancel printing, press the <Stop/Reset> button.
To continue printing, press <Black> or <Color> button.
After printing completes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause the machine to malfunction.
5
The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur.
7
The ink cartridge is not installed in the appropriate position.
The ink cartridge is not installed in the proper position.
Install each ink cartridge in the proper position.
8
The waste ink absorber is almost full.
The waste ink absorber is getting full.
Press the <Black> or <Color> button to clear the error and continue printing.
Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
9
A specified period of time has elapsed without receiving a response from the digital camera. / A print mode compliant with PictBridge is not selected. / A specified period of time has elapsed without receiving a response from the digital camera.
The machine cannot communicate with the connected camera.
Disconnect the cable between the machine and the camera to clear the error.
Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the machine.
1 , 4
1 , 5
The ink cartridge cannot be recognized.
An unsupported ink cartridge may be installed.
Install only recommended ink cartridges.
1, 6
The ink level cannot be correctly detected.
A used ink cartridge may be installed, or the ink cartridge is empty.
Replace the ink cartridge.
Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
1 , 9
Scanning failed.
Scanning a document failed.
Check if the document is placed in the correct orientation / position and try the operation again.
2 , x
3 , x
4 , x
(Where x represents a number)
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on.
If the problem is not resolved, the machine may require service.
Feb 18, 2012 | Canon PIXMA MP150 All-In-One InkJet...
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
If the camera does not support either one, the printer cannot print directly from the camera.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Dec 27, 2009 | Canon Office Equipment & Supplies
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
Text is not printing clearly.
Change the photoorganic drum and the cleaning blade,if the cartridge is refill 2 or more time change the cartridge.
Sep 07, 2009 | Office Equipment & Supplies
Hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 24, 2009 | HP PSC 750 All-In-One InkJet Printer
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Using far too much ink
This came from brothers website:
The Yellow ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Magenta ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Cyan ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Black ink cartridge yield is up to 350 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
so it appears that what you are experiencing is not normal and you may have a leaking printer.
There is one thing you can check though, everytime you print, make sure that you are not printing at the highest quality option selectable as this almost certainly will fire out more ink than regular printing... choose a middle quality option or even draft option if you will be printing regular text.
Jul 02, 2008 | Brother Office Equipment & Supplies
Printing blank pages
Blank Pages Printed
Remove the protective tape from the cartridges:
With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
Remove the cartridge(s) from the printer.
Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
Clean the cartridge nozzles:
Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
Clean ("wick") the cartridges:
Remove your cartridges following the instructions in your User's Guide.
Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Mar 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
66 people viewed this question
jasbo
jasbo
