Question about iLO DVDRH04 DVD Recorder
Disc tray cannot be opened
Disc tray will not open; after powering up, machine is frozen at the "HELLO" message. Tray won't open either with the button on the recorder itself, or using the remote.
  • Anonymous Mar 27, 2014
    Disc tray will not respond to button
  • Anonymous Mar 28, 2014
    Can not open the disc tray. Have tried both manual and with the remote
    Brigadier General:
  • 6,966 Answers
Hi, The unit is in initialization/reset mode immediately after powerup. It does a self diagnostic sequence. When a fault is detected, it actually locks up till the fault is removed/repaired. A couple of things you can do: 1. Unplug the unit from the mains for a couple of hours; 2. Check your manual if there is a hard/full reset sequence/button and perform it; 3. Remove the topcover and inspect the loading tray. There is a possibility that a CD is stuck, lodged or skewed inside; 4. There is also a possibility that the loading mechanism is stuck, defective belt/gear; 5. if the unit is still under warranty, require service or replacement; or 6. if no longer under warranty, seek the services of a qualified professional. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 15, 2007
  • Louie  Role
    Louie Role Sep 15, 2007
    Hi again,
    A few reminders should you care to do a fix-it-yourself: There are live voltages inside when working with a plugged/powered electronic device; opening the unit would void your warranty; it is possible that it is a software glitch/error and in some units, a PC is required to be interfaced to the logic circuitry of the DVD; the laser emission although relatively low power can still pose a health risk hazard; if you are unsure and do not feel comfortable working inside the unit, then perhaps #s 5 or 6 would be to your advantage.
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Disc tray frozen in closed position
Unplug it for a few minutes to reset it and then plug it back in again.
Apr 29, 2008 | Samsung DVD-R130 DVD Recorder
Yes when I try to open the Xbox 360 disc tray the power button in the center flashes as if the disc tray is opening, but doesnt open. it flashes even when i havnt pressed a button for it to open the d
Try turning off the 360 then turning the xbox on its side, turn the machine back on holding the eject button and the power button together for about 30 secs then the machine should function normally
Jun 19, 2014 | Microsoft Xbox 360 Console
DVD/CD disc opener won't workGetting
Usually the tray has to be opened and inspected and if lucky it can be realigned--if not parts may be hard to find as they usually do not sell individual parts for the mechanism.
Nov 05, 2012 | Televison & Video
Disc tray won't open
Open a paper clip and push one end into little hole next to disc tray. push hard, the tray will open.
Jul 19, 2012 | HP Pavilion a1640n (RC663AA) PC Desktop
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
Toshiba sd-4205 5-dvd carousel changer declares mecha error during startup, will not eject tray.
This may not work for everyone, but.....
I had the same problem with the Toshiba SD-3205. After unplugging, trying button combos, etc, nothing worked. I could here a slight whine inside the machine, and then again...."MECHA ERROR".
I turned the unit on its side to see if there was a manual tray button on the bottom. Nothing. Then just to try it, I turned the machine off and on again while on its side.
It started up, I heard a clatter, and then the display changed to "INSERT DISC". I placed it the right way up again and pressed "OPEN TRAY" and it worked!
My theroy: There was one DVD in the carousel, and I think last time the tray shut, it got wedged somehow and prevented the carousel from rotating. Turning the machine on its side and pressing "OPEN" is what dislodged the disk.
Jul 09, 2008 | Televison & Video
Disk Tray
  1. Ensure the child lock feature is disabled.
  2. IMPORTANT: If necessary, consult the instruction manual for specific steps about how to disable the child lock feature.
  3. Attempt to open the disc tray.
  4. If the issue is not resolved, turn off the DVD player.
  5. Unplug the power cord from the electrical outlet for 30 seconds.
  6. Plug the power cord back into the electrical outlet.
  7. Attempt to open the disc tray.
  8. If the disc tray still does not open, simultaneously press the POWER+STOP+EJECT buttons; this will sometimes cause the disc tray to open.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
see this
Sergio
Mar 29, 2008 | Sony RDR-HX825 DVD Recorder/HDD Recorder
Jvc xv-thc3 tray is frozen
The changer mechanism needs to be manually reset. Maybe due to a broken gear.
Oct 28, 2007 | Audio Players & Recorders
Sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
you should try inspecting & servicing the tray transport mech first and then the tray sense swt.
Dec 08, 2006 | Sanyo DVW-6100 DVD Player/VCR
iLO DVDRH04 DVD Recorder Logo
203 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
