Question about Vtech IA5854 5.8 GHz Cordless Phone
I turned the ringer off on my phone and now theres no dial tone.
I turned the ringer off bc my baby was asleep. The next day theres no dial tone and still doesnt ring even after turning the ringer back on. Please help : )
Unplug the phone entirely for about 5 minutes and then plug it back in and see if this works.Good Luck!
Posted on Apr 15, 2009
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Have a V-Tech 6.0 phone CS6319 Series - Battery OK - turns on, but NO DIAL TONE. We do not have manual, Do not see anything like Mute On/Off in menu. All connectors and plugs are secure. Help?
First, does another phone get a dial tone at the jack in question? (I prefer an old corded phone for this test since it is unlikely to have some of the problems of a cordless.) Try a new phone cord between the base and the jack. If there is no dial tone, try the test phone at other jacks. If there is no dial tone at any jack with either phone, find where your telephone service comes in and open the service box. If you are lucky and have a fairly new connection, the service box will have RJ-11 jacks. Plug your test phone into the jack and check for dial tone. Otherwise you will need the phone company to do this test. If there is no dial tone at the service box, your phone company will fix the problem for you for free.
If your test phone works:
Make sure that the base is plugged into a working outlet (no tripped circuit breaker, turned off power strip). Next check that the handsets are registered with the base. To register the handset, press the Find HS button on the base (below the in use indicator) for 4 seconds, then press # on the handset. (Our cordless phones once lost their registration during an extended power outage.) You can force deregistration by pressing and holding Find HS for 10 seconds. The In Use light should come on and flash. Then release the Find HS button and then press and release it again while the In Use light is blinking. You may need to try unplugging the base after pressing Flash/Talk and then Off/Clear before deregistering the handsets. The register the handsets.
You can Mute the microphone on the handset with the Mute button. To silence the ringer, press Menu/Select when the handset is not in use. Use the up/down arrow keys to select Ringers then press Menu/Select. Then press Menu/Select to choose Ringer Volume. Use the up/down arrows to change the volume and then press Menu/Select to confirm and save the setting. This should not change the ability to hear the dial tone.
If your test phone works at the service connection but nowhere else, then you have a wiring problem inside. Check exposed wires if you have them. Your phone company will offer to fix the issue for a fee. If the problem is at one jack, open the faceplate and check for loose wires. Some faceplates use a keystone with a punch-down tool to secure the wires. Others just wrap the wire around a screw for each pin.
If the handsets are registered and the base has power, then the cordless phone has problems. If it is under warranty, have it fixed. Otherwise, replace it; they aren't made to be user serviced.
The manual is available here: http://www.vtechcanada.com/support_docs/vtt/CS/CS6319_en_cib.pdf .
I hope this helps.
Apr 22, 2011 | Cell Phones
No dial tone or ring
Your Phone Ringer Default SO Please change Ringer
And Dial tone and Ringing Problem will Solved
Aug 15, 2010 | Uniden Lands Phones
Phone has dial tone but does not ring
Aug 15, 2010 | Cell Phones
My handset ringers are ''off''. How do I turn them on again? Uniden TRU4985
Hi there try this,
When the phone is in the standby mode, press menu/mute.
2) Press select/ch.
3) Press + or - to move the pointer through the ringer
settings (Ringer Off, Ringer Low, or Ringer High).
You will hear a ringer or melody at the selected volume.
4) Press select/ch, you will hear a confirmation tone.
Ringer Mute (temporarily)
You can temporarily mute the ringer tone. When the handset is off the base and the
phone is ringing, press end. The ringer tone will return to the previous setting starting
[ 20 ] BASICS
• If you select “Ringer
Off”, “Ringer Off”
appears on the display
when you make or
receive calls, or
charge the handset.
Ringer Volume Setup
1) When the phone is in the standby mode, press menu/mute.
2) Press - to move the pointer to “Ringer Tones”, then
press select/ch.
You can choose from 6 ringers or 4 melodies:
- Ringer [Flicker, Clatter, Leap Frog, Ping Ball, Reminder,
Soft Alert]
- Melodies [Beethovens9, For Elise (Elise), Merry Christmas
(Merry-Xmas), Home Sweet Home (Hm Swt Hm)]
3) Press + or - to move the pointer. You will hear the ringer or
the melody as you scroll through the options.
4) Press select/ch and you will hear a confirmation tone.
Ringer Tone Setting
• If
Sep 27, 2009 | Lands Phones
The ringer is off and I don't know hoe to turn it on
I have two uniden phones 2.4 GHz and the ringer is turned off and we cannot figure out how to turn it back on again. Please help!!!
May 18, 2009 | Uniden TRU4485-2 Cordless Phone
Telephone has a dial tone but cant dial out
talk with a technician about a problem phone line filter for the internet
it is possible that it has failed and the adsl and phone frequencies are giving a problem to the phone operation
Apr 21, 2017 | Vtech Lands Phones
Mh9915 bellsouth
go to the shop from where u brought this phone & get the ringer changed
Mar 28, 2008 | BellSouth GH5816 Cordless Phone
Unable to dial out, check voice mail and see call display
Hi at the back of the phone you will see a selectable Hi/Lo/Off switch. Slide the (Ringer) switch to High position or Low position to turn the ringer on. Hi for high volume Lo for low volume.
To prevent hearing any ringing of incoming calls slide the (ringer) switch to the off position but when you ready to accept incoming calls again remember to slide the switch back to either Hi or Low setting. Hope this made sense and helped.
Oct 24, 2007 | Curtis Trimline TID582 Corded Phone
Vtech IA5854 5.8 GHz Cordless Phone Logo
276 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
