Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Buzzing sound clicks on and off from underneath fridge
I have an Admiral 26cu ft side by side fridge. Just recently I hear a loud buzzing, electrical sound from underneath the front of the fridge. Goes for about 20 seconds then clicks off. Quite loud. Not related to ice maker. Fridge and freezer still work fine as does Ice machine. What is the noise and how do I stop it???
  • 121 Answers
That would be your relay going bad it will stop the fridge all together change it to a 3 and 1 relay
Posted on Apr 17, 2009
My 2005 Admiral side by side has stopped keeping things cold everything in the freezer has thawed and the fridge part is now over 70 degrees there is power as the lights are on and it sounds like the ice...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Admiral 26 cu. ft. Side-By-Side...
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
Have a n admiral fridge freezer. The freezer is not keeping temperature. Sometimes food is defrosting.
heatman101
Jun 22, 2011 | Admiral 26 cu. ft. Side-By-Side...
Admiral refridgerator model lsd2615hez is making a buzzing sound every 2 minutes. The buzzing sound lasts 20 seconds and everything in the freezer is melting. What could be causing this?
what you are hearing is the compresor trying to start . and can not so the over load is shutting down . and when it cools it will try again .. you need to replace the starting device on the compressor .cost about 80.00 parts .. most models . some are more. and the melting is caused by no comp runing .. this is a very common problem .. hope this helps mm feed back pls .
Feb 01, 2011 | Admiral 26 cu. ft. Side-By-Side...
My american fridge/freezer keeps tripping the electricity board?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Dec 25, 2010 | Admiral 26 cu. ft. Side-By-Side...
My amana refrigerator model number ASD2620HRR, 26cu ft is making a buzzing noise and has stop getting cold
42434
Sorry to hear about your problem.
Your main control card is defective. and or your compressor is causing the card to fail, or the card is trying to start the compressor.
You will need to call a service company to resolve your issue.
Since I tried to help you, please help me and rate/vote this response. Thanks and good luck.
If you live in the Denver,Co area I can help you.
Dec 23, 2010 | Amana ASD2522WEB (25.1 cu. ft.) Side by...
My fridge doesn't seem to get cold enough anymore. There's water dripping from the ice tray last night. I hear a buzz sound, like the fridge is trying to start up, but then nothing happens. Any ideas ?
replace the rtc overload contactot located on the side of the units compressor,it is defective and not letting the compressor start and then go to run properly,its easy to install,just unplug the bad one and replace it
Feb 24, 2010 | Admiral 26 cu. ft. Side-By-Side...
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
356 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
