Question about RCA F27650 27" TV
NO POWER Hello, My Tv will not turn on completely. I took it apart and the fuse is still good and I can't find any discoloration in the circut board and the wires are good to go. There is no sound and no picture so I was thinking it has to do with power supply. If you can help me out, it would be greatly appreciated. Thank you, John
    Scholar:
  • 136 Answers
If the unit turns on then off quickly or there is a squeeling noise from the power supply (usually faint but noticable) there is a short and the switching powersupply is shutting on and off rapidly. Usually on RCA's the Horizontal output transistor and flyback go out on this model alot.
Posted on Sep 15, 2007
SOURCE:
Surge outage tv not coming on
Quite possibly just blew TV fuse, but may have more damage, usually to the power supply circuit.
Unplug TV & remove back & do a visual inspection of all PCBs & wiring. your looking for physical damage, traces of arcing, parts blown apart or damaged/discolored.
Jul 22, 2014 | LG Televison & Video
Want to check fuse on 46h83 toshiba
only fuse I know is near back of tv inside power section right next to the power cord input ... my first thought tho is damaged capacitors inside same area ... good luck getting it apart ... I took mine apart but difficult to figure how
Jun 10, 2009 | Toshiba 46H83 46" Rear Projection...
All electrical circuts work no blown fuses,can arc starter sylono
I had the same problem with 2001 v-92, I thought starter button was faulty so i took complete throttle handle muose trap apart, and it was clean and lubed. it still would not start. power was not comingto start button. problem was ecm relay. under right side cover. auto store said gm had lots of trouble on their autos with this relay. replaced it with another relay and end of problem. Also it back fired once starting from a stop sign, I mean loud! scared me to death! Relay fixed problem. My speedo went out also. same relay!
May 11, 2009 | 2001 Victory V 92 C Deluxe
Was welding 10 min later mach. quit power was good circut breaker was good and fuses were good
it probably has a fuse for overheating safety, or else the feed motor fried
Apr 24, 2009 | Welding Tools
I have a 42" sanyo plasma flat panel tv. I was watching, and all of a sudden the screen went black. I did still have sound. I messed with the remote for a few minutes...then heard a pop...then tv was...
hello, you have a (shutdown circut) it happens when the tv senses trouble in the circut.
becuase these type of tv's run hot at high internal voltages parts can become overheated and loose proper resistance or ability to handle voltages that have to reach other parts of the circut and other internal board panels. a shutdown it is for protection. you may want to check your power supply if there was a pop that is something inside that went bad. be careful to touching inside theres is high voltages stored in the components.
i can not tell you specifically what your primary cuase was without your model service manual. no power means power supply trouble.
replace or trace.
what ever blew out cuased the power supply to go bad you will need a service manual to know for sure.
the wise chioce is to have a service center check it for you they will know what to repair or exchange.
good luck hope this helps
Jan 08, 2009 | Televison & Video
Power won't stay on
hello. you are not alone, this is a common problem with alot of new lcd and plasma tv's since they operate with high internal voltages the circuts have built in protection. any slight power fualt or short in the circut will cuase a sos or shutdown. may be a number of different reasons or even a shorted fuse.
it needs to be checked you have a power issue.
some models if there is a blinking led the number of blinks indicates the fualty area.
your tv needs service.
hope this helps
Dec 17, 2008 | LG Televison & Video
Totally dead. Vizio GV42L
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
Dec 03, 2008 | Vizio GV42L 42 in. LCD Television
Tv will not turn on - watch and heard a pop a shut off
it probly had a power surg and blw a fuse ther r like five one in each corner and one ine the midel had same prolblum the glass braks on the fuse thet probley was the pop u heard
Nov 10, 2008 | Televison & Video
RCA P60752EB Power problem
Apparently, blown fuses indicate problems elsewhere in the circuit. The block is a voltage dropping resistor, has nothing to do with problem. If you think it's worth it, take to pro/tech
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need in assistance in repair
I did the same thing and found that the solder from the battery tray and the circut panel came apart. Check it out. Just somthing to check. Good luck
Feb 14, 2008 | Night Owl Optics Light NOLT3 Monocular
Open Questions:
Letterboxing: The top and bottom of the screen are cut off I originally obtained this TV from my Bro who passed away from cancer at age 31 a few years ago & I was never able to find out what he did with the manual. However, I was able to find a manual online but after viewing it, I still wasn't able to find the info. that I am trying to obtain for the correct settings to get rid of these black margins at the top & bottom of the screen. I am trying to find out what video output format is supported by this TV model, as far as the resolution and output format, specifically for a Cisco or AKA Scientific Atlanta 500GB HD-DVR through Cox cable? My available settings with Cox cable & the DVR I have( Cisco or Scientific Atlanta 500GB model)are the following-Resolution:480i, with output format of either:Zoom 16:9 Pic or Letterbox 16:9 Resolution:480p standard, with output format of either:Zoom 16:9 Pic. or Letterbox 16:9 Resolution:480wide, with either output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic Resolution:720p wide, with output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic and finally, resolution:1080i wide with output format of:Stretch 4.3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic? Everything worked fine with the screen size when I had a 160GB Motorola HD-DVR with Cox under the video output settings of:resolution:480i and video output of:Zoom 16:9 Pic until, I grew tired of constantly running out of space & had them switch me to a 500GB HD-DVR. They were supposed to install another Motorola HD-DVR but just with 500GB version but when the Cox maintenance employee showed up to swap them out and install the 500GD HD-DVR, he only had a Cisco/Scientific Atlanta 500GB available on his truck, which is I guess what they use for the Contour service but he attached a filter to the back of the coxial cable to make it a regular HD-DVR without Contour(even though they tried charging me extra for contour for 3 months before I finally got that straightened out since the maintenance workers & billing dept. are often not on the same page as I found out at Cox. I have tried calling Cox for support & they say that I need to find out & know my TV's video output settings. I explained to them that it worked perfectly fine just weeks ago with 480i resolution and output format of Zoom 16.9 Pic before they switched to the Cisco/Scientific Atlanta HD-DVR from the Motorola DVR and that I didn't have the manual and I stated why and they basically said, too bad, figure it out yourself. Can someone please help me out? I have the TV set up for the correct zip code, cable box-Yes, the cable box output channel-video 1/Aux (since that is what the TV manual I read online said to use if you are using the 3-color coded cables instead of the coxial cables to plug in from the TV to the HD-DVR) & I have the Cable box remote control code set to code 008 (Scientific Atlanta) that I verified to be correct by checking it through the TV's automated code search. The serial # for the TV is:C306B2084 and the Chassis # is:ATC113BB1 and its the 27" RCA Entertainment Series Guide Plus Gold Gemstar that is X-Box ready. Thanks so much, Todd
Feb 26, 2017 | RCA F27650 27" TV
RCA F27650 27" TV Logo
81 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
