Question about HP Color LaserJet 3500 Printer
Yellow runs out after only a few hundred prints and didn't used to
I've had my HP 3600 for about 2 years now. The first yellow replacement cartridge lasted almost 8 months. I've had to replace the yellow cartridge 3 times now since Christmas, and my usage of this printer is definitely less than the first year I bought it. Is it possible that the yellow isn't actually empty and the sensor is malfunctioning? Is there a way to bypass this sensor? Please help! Big deadline tomorrow! Lisa Mayer
    Habit-Forming:
  • 8 Answers
Not sure why you're going through the yellow toner so quickly. You might try pulling it out and shaking it some to re-distribute or loosen the toner inside.
Yes you can override the cartridge out of toner print halted problem. This is located in your User's manual and is stated as:
Replace Supplies feature
The printer has three options for low or exhausted supplies status:
STOP AT OUT (the default setting): The printer continues printing while a print cartridge is low.
When the cartridge is out, the printer cannot print.
STOP AT LOW: The printer pauses until you replace the low cartridge.
OVERRIDE AT OUT: The printer continues printing even after some supplies have run out.
To set the Replace Supplies feature
1.
Press Menu.
2. Press (down arrow) to highlight CONFIGURE DEVICE, and then press (check mark button).
3. Press (down arrow) to highlight SYSTEM SETUP, and then press (check mark button).
4. Press (down arrow) to highlight REPLACE SUPPLIES, and then press (check mark button).
5. Press (down arrow) or (up arrow) to select the appropriate setting, and then press (check mark button) to set the selection.
● If you select OVERRIDE AT OUT and then press (check mark button), a warning message appears. To accept the override, select YES, USE OVERRIDE and press (check mark button), and then set the page limit for the override and press (check mark button).
6. Press Menu to return to the Ready state.
Posted on Apr 16, 2009
I have an HP Color LaserJet 3700 that has decided to stop printing yellow. I have changed the cartridge several times and have run all of the diagnostics/calibrations many times with no success. I want to...
Press Menu. Drill down to Diagnostics
Go to DISABLE CARTRIDGE TEST
Now swap the Yellow and Black cartridges.
Print a Config page. If Yellow doesn't print, your cartridge is bad. If Black doesn't print, you could have a bad laser/scanner
Feb 05, 2010 | HP Office Equipment & Supplies
Help when I print i get yellow and black lines across the page through out from top to bottom for an HP 3600n laser printer
First thing to do is exchanging the black and yellow cartridge. Mostely the problem is solved.
Jul 11, 2009 | HP LaserJet 3600 Printer
HP will not recognise new cartridge
The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Color Lserjet 3600
We found that we had a defective cartridge. We returned it. A replacement cartridge did not cause the printer to callibrate continuously.
Jan 10, 2009 | HP LaserJet 3600n Printer
HP leaser jet 3600 doesnot print yellow
Clean the toner contacts in the printer
May 15, 2008 | HP LaserJet 3600n Printer
Hp 1200 business inkjet help
I have a solution that is very similar to that printed above.
I have tested it on five installations on the computers on my home network and an HP Business Inkjet 1100, and the PCs running Win XP SP3.
Step 1) If you are setting up the printer from the HP CD, decline the question where it asks if you want to print a test page, (this will avaoid the first print job before re-setting the dates).
Step 2) Reset your clock back to a year prior to the year when your cartidge expired.
Step 3) Print a test page, or two. Or a few pages from any application.
Step 4) Reset your clock back to the current year.
The printer now prints fine. Since I performed the sequence above I have been printing with the "expired" cartridges for a few weeks. I have printed on about 15 occasions over the past few weeks, amounting to about 50 pages. No problems so far. I don't know how long this solution lasts or whether I will have to go through it again.
I have gone through a few different "solutions", including a Registry hack that didn't work, but this simple solution above has worked every time on five different installations.
I did not need to turn the printer on/off, and did not need to re-boot the computers.
However, if I sent a print job to the printer before performing the sequence described above, and the printer gave an "expired cartridges" error, then I would need to turn the printer on/off to clear the error, and flush the print queue.
Jan 28, 2008 | HP Inkjet 1200dn Printer
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP Color LaserJet 3500 Printer Logo
230 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
