Question about Nintendo DS Console
No power; won't turn on w/charger
The DS was fully charged, and was being played with, though we noticed the volume was low at max setting. When my husband changed out one game for another, it shut down and now won't show any signs of life except for brief flash of the orange power indicator light when the charger is first inserted. Before I dismantle my other DS to switch batteries to verify it even is the battery, do you have a suggestion or can you confirm if this is a battery issue? Thanks in advance for any help you can provide, Jen
    Problem Solver:
  • 5 Answers
Im only 9-12 so i dont know alot though leave it in for 5 hours tops and maybe your game was set on low so check the settings.... its surpose to be orange..made sure the DS is turned OFF so that engery isn't going while charging if this doesnt help which battries if that doesn't help.... get a new DS
Posted on Apr 16, 2009
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
I got my DS in 2009 april, then on september i lost my charger then on march 2010 i found my charger then i found out i could'nt find my DS anymore a few months later i found my DS i charged then it...
The red LED indicates low power. When the DS is charging an orange LED should be on and the DS can be switched on, giving a second green light. If you tried charging it but the orange LED did not come on or only came on for a few seconds then the battery has not charged. The charger may be faulty or the power connector on the DS may be faulty. You need to try another charger. If another charger does not work then the DS is faulty and needs repair. It could be the power connector or the battery or some other fault inside.
If the amber LED comes on to indicate that the battery is charging then the battery should be fully charged within 3 hours. If the DS does not switch on after charging then the battery may be faulty. It can be removed by opening the cover on the bottom of the DS.
You should try and find a friend with a DS who will let you try their charger and battery in your DS.
If the DS itself is faulty it will probably be uneconomical to repair. If this is the case then try selling it on ebay as a faulty DS.
Oct 30, 2010 | Nintendo DS Lite Console
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
My ds is automatically shutting down..
put the charger in and then turn it on
Jun 19, 2009 | Nintendo DS Lite Console
Putin in charger orange light flashes then goes off an doesnt cha
Your DS is either fully charged or the battery got damaged/wet. When you play the DS, is the light red or flash red? If it does, then the problem is with your battery. http://www.nintendo.com/consumer/repair/dslite_repair_home.jsp
Click on your country, then "System and Game Problems," then "Power and Battery Charging Problems."
Hope this helped.
Apr 15, 2009 | Nintendo DS Lite Console
Busted DS Lite Charger
Go buy a new charger. Chargers are made cheap so the thread wire underneath the rubber on the charger probably snapped or wore out. Go buy a new charger :) That should solve it
Apr 04, 2009 | Nintendo DS Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Ds power problems
mmm not exactly because if you plug the charger back in it will go orange again, so my guess would be that the ds doesnt stay charged for a long while, you can charge the ds properly when it is shut off but it does needs to be charging at least 8 to 10, you want it to last longer, play a game till the power goes just dnt save anything incase the ds shuts down while saving, otherwise it can corrupt the game and possibly the ds
Jack
Mar 12, 2008 | Nintendo DS Lite Console
DS lite not working
there may be some kind of damage in the ds as i had the same problem it may have been shaken around or dropped or even faulty the best thing to do is send it back if you dont have the warranty then go to a gaming store most have a collection day where someone comes to pick up broken ds and takes them its free except tfor the repair.Its best if you dont fiddle around with it a it will become more damaged
Jan 05, 2008 | Nintendo DS Lite Console
Ds light not coming on and charger not working
When I hooked up my DS with the charger the orange light would flicker for only a few seconds then turn off.
I found out that if you KEEP THE DS ON WHILE HOOKED UP the DS will charge. Although, because you are playing/DS is on the charging will go extremely slowly.
Best option, and what I did, was was just return/exchange it. I just did that today.
Nov 28, 2007 | Nintendo DS Console
Nintendo DS Console Logo
60 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
