Question about Aloha Housewares Breeze 29" Tower Fan
I'm trying to clean the fan
But I don't know how to get to the filters. How do I clean it?
  • 293 Answers
The least you can try is by using a vacuum or airblow on the fins.
Posted on Sep 15, 2007
I like to clean the air ports but i don,t know where to locate it in order to clean it
What model Sony Laptop? A laptop's easy, follow the sound of the fan, usually on the bottom, vents on the bottom and sides.
Feb 27, 2013 | Sony VAIO Computers & Internet
I don't know how to clean the filter
pay a pool guy to show you how, there is hundreds of filters out there and they all have there little tricks to do it right . you might just find it smarter to have a pro take care of your pool. .. jay
Sep 16, 2012 | Sta Rite Pool & Spa
1994mitsubishispacewagon still overheats after replacing auxilliary fan sensor, cleaned the hoses, pls help
Thermostat stuck take it out. leave it out .. try it ...then
put in a new one...or water pump weak. Also try wiring the auxiliary fan and any other fans so that anytime the vehicles motor is ON the fans are ON don't depend on a sensor on a Mitsubishi of that that don't come on soon enough, or stay on long enough, or turn on at all without letting you know until the motor overheats..... , are the leading cause of death for vehicles~!! lol
Jun 22, 2012 | 1994 Mitsubishi Expo
My computer keeps turning off i not sure what happening with it my hard drvie is fine and power supply but you see the fan that keeps it cool well i don't know but the cpu is a hp with window 7 and...
do you mean 1gb of this is not a ram issue ,sounds more like overheating or cpu fan is old is pc and have you clean the fans since owning it.Its a common problem .where do you keep your pc tower ,if on the floor then you may find your fans for your cpu,power,graphic are coated in dust,and you may find your fans are overheat due to the weight add and no Im not joking .try clean your fans and cpu cooler fins.don't use a vacuum cleaner like some people do as you can damage your chip-sets on your motherboard .buy a can of compressed air from pc store and make shore the fans dont spin when clean as it can short your cpu,graphics card.cpu fan clean gentle with cotton bud.if this does not work try replace your cpu fan. hope this helps let me know how you get on. ..............DT
Sep 07, 2011 | Microsoft Windows 7 Ultimate for PC
Brada ypm-06c air conditioner not cooling the room down no matter what i do! keep getting E3 code. is it normal for the lcd lights to keep blinking and blinking! SO annoying when in the bedroom at...
You need to clean the filters and coils on this unit so the error code will go away and the unit will work like it should. If it can't get clean air across the coils it will freeze up and not circulate any air. Most common issues are dirty filters and dirty coils that prevent air flow. Is the fan working to blow air? this code could also mean the fan is not working. Check on these and let me know.
Aug 05, 2011 | Heating & Cooling
DDR2504 dehumidifier has always worked well. Now the fan runs and all seems normal, but the humidity is not dropping and you can tell that the dehumidifier is not cutting in and out. I do not have it on...
derkfarm - It may simply be a case of the humidity extraction level being set to high and/or the air intake filter needs to be removed and cleaned.
Solution: Lower the humidity extraction level to 32 - 35% and clean the air filter.
If the unit is in a basement, the ambient air temperature at floor level is colder than at chest level. Dehumidifiers don't work well at temperatures between 40 - 60 degrees F.
Solution: Set the unit up off the floor on a sturdy table, cabinet, counter top, etc. It must be sturdy enough to handle the weight of the unit, plus a full tank of water and the vibration, while in operation.
Any or all the simple solutions above may solve the problem. But, we won't know, until you try them.
Please let me know if it helped or didn't solve the problem. Thanks.
Jun 15, 2011 | Danby DDR2504 Dehumidifier
We purchased this swamp cooler second hand so do not have a manual. The fan makes a tremendously loud noise when it runs and I'd like to know how to repair that. We also do not know how to change the...
Cleaning should be a regular task (at least yearly). Fan is probably hitting something, or the crud attached to it is hitting something.
Sometimes you just have to brave it. Consider this: You can't break what is already broken. Use tape: Apply all screws to tape -- don't loose them. Do not bend the fins -- air needs to freely flow past them. Do not puncture one of the pipes -- freon needs to stay in them.
Above all: Hum a tune while you clean and wear a smile or you might upset the cooler.
Just because I did not tell you to unplug it does not mean you should get stupid. Wear your thinking cap and a smile :o).
Jun 02, 2011 | Heating & Cooling
Took filter out to clean and now have a humming sound when the hood is turned on but the motor is not working.
When you took the filter out to clean it you got something against the fan blade....probably when you reinstalled the filter,,,pull it back out and try the fan... if it works then you know the filter is installated wrong...
Mar 14, 2011 | Baumatic Kitchen Ranges
Lg tdc70040e I have this dryer. I dont start
Make sure the exhaust vent line is not clogged. Check the entire length all the way to the outlet.
Jul 19, 2009 | Dryers
Aloha Housewares Breeze 29" Tower Fan Logo
285 people viewed this question
Top Aloha Housewares Dryers Experts
Cesar Quant
Cesar Quant
Craig Butler
Craig Butler
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
