Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
HP ZV 5000 laptop AC adaptor switches to battery power randomly. The AC adaptor has only one year of usage on it and it works fine when the switch to battery power problem (luckily) doesn't occur. Also the connection in the back seems to be sturdy i.e. not loose. Is this a software problem? Any help will be greatly appreciated.
  • ashish_si248 Apr 24, 2009
    Thanks for your response. I would look into acquring a new adaptor from EBay, if it is not as expesnsive as one I purchased from HP. HP sold me one for $180. Hopefully that would take care of the problem. Otherwise I may have to go down the road of process of elimination (one variable at a time) to eventually zero iin on the real problem. Thanks again!!!
We have two different HP Pavilion laptops, and they've both done this. For us it hs been the AC cord itself where it plugs in to the computer that has been the problem. Personally I think it is a scam with an imminent design failure built in. The cord bends right after the plug over an over again until the cables inside start to break and or short. At first you can get it to work by angling the cable just so until the charge indicator comes on, but after a while it just gets too far gone.
The scam part for ALL laptops that I have seen is that the cable is not replaceable. You have to replace the whole adapter. Of course the section of cable from the wall to the adapter is replaceable, but the cable from the adapter itself to the computer is hard wired, and that is the only part that breaks!
I have had minor success in repairing or replacing the ends, but the best fix is to get a new one. eBay has some for much cheaper than HP.
Posted on Apr 24, 2009
My Lenovo s10 power adaptor (Input 1.7A, Output 20V 2A) was working just now together with the battery. After i didn't used the laptop for an hour and returned to switch it on, the power adaptor isn't...
hi,
You said laptop is working fine if just using the battery,that means that there is nothing wrong with the battery itself. Can yu please try to connect the laptop directly to the power outlet without using the battery just for the mean time,remove the battery and connect the AC adapter directly to the power outlet then power on the laptop,if nothing happens,that means that there is something wrong with the AC adapter itself or the power port on the laptop.
Hope this will help...
Jan 09, 2011 | Lenovo IdealPad S10 Laptop AC Power...
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
Pavilion dv6700 AC Power. My DV6700 performs perfectly on battery, but will not charge the battery or run straight off AC. AC Adaptor, Batteries and AC jack have been tested in fine working order. Any...
Hi, believe it or not?; sometimes the current in certain areas of the home or apartment have separate power circuits from the main direct current system. Check to make sure there is electrical current running through your socket, and or light switch to open the circuit. Thanks, paul7of9
Dec 29, 2009 | HP Pavilion dv6000z Notebook
My HP laptop cannot be switch on problem with virus
do a power drain
1. shut down the comp
2. unplug the ac adaptor
3. take out the battery
4. without any power connect to the comp
    press and hold the power button for 60 seconds
5.after 60 seconds plug the battery
6. plug the ac adaptor
7. turn on the comp
Oct 20, 2009 | HP Pavilion dv6000z Notebook
HP ZV 5000 AC PROBLEM
You either have a bad adapter or a broken power jack in the laptop. To check the adapter use a multimeter set to voltage and connect one lead to the center in and the other to the outside metal contact. You should get a reading from 18 to about 26 volts. If you get no reading then the adapter needs to be replaced. If you get the correct reading then the power jack in the laptop will need to be replaced. If yo are ok with electronics repair you can get the jacks from Ebay.com if not your local computer repair shop should be able to do it for you.
I hope this helps, If so please rate my solution,
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair.
Jul 08, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Hi. My HP nx7000 Notebook does not switch on at all
If you have warranty get it in for a new m/board ok
May 07, 2009 | HP Compaq Business nx7000 Notebook
Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
Jan 29, 2009 | Dell Inspiron 6400 Notebook
HP Pavilion zv 5316 us Recovery Discs
fixha sells you nothing, its just chat box free.
and is not HP,why ask here.
good luck finding free disks.
good luck matching exact model, that 's right exact.
and never post email addresses, unless getting SPAM for 1000 years is fun, or safe.
why post here at all, ask real HP>
https://h30434.www3.hp.com/
HP does not sell disks on non-supported PC,s (too old)
so ask them , or find them on ebay, or use craigs list
and post WTB wanted to buy, this is not buy sell forum here at fixya but good luck if you do get offers.
see the 2 links below, that are 2 ,HP recommended 3rd party selles
of install disks.
by the way, if buy disks from random sells, they will be infected.
if XP , x1000 that. idea.....
http://pcdied.com/HP-OS-GET.html
Jul 17, 2017 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Ive reboot my laptap hp pavillion zv 5000 but sound doent work
i agree with exon33 as long as you are useing realtec you can do that anything else and you better off using the disks that came with it
Apr 21, 2008 | HP Pavillion ZV6000 Notebook
HP printer AC power adaptor 0950-4399
I want to purchace new HP printer AC power adaptor 0950-4399 from mumbai where shall i contact
Mar 26, 2008 | Office Equipment & Supplies
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
261 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
