Question about Maytag Performa PAV2200
Water is running all over the floor - Maytag Performa PAV2200
    Champion:
  • 219 Answers
U can take a putty knife and push in clips on front panel about an inch in on either side to lift the top remove screws from front panel then u can run it to see where water is coming from
Posted on Apr 17, 2009
Major water leak when it rains, water runs down driver side floor
Keep looking by covering area at hood etc and running water on the vehicle to locate where it is coming in---Windshield?
This is the best way if you cannot trace the stains from water to source.
Dec 10, 2012 | 1999 Ford Explorer
AC water leaks inside car, 2002 mercury sable
You probably have two different issues here.
The water on the floor is usually caused by a drain tube being stopped up. The tube is supposed to let the water drain out of the car and onto the ground. It should be on the bottom of the firewall or below the floor.
You would need to have the computer scanned for trouble codes to find out why the check engine light is coming on.
Jul 19, 2012 | 2002 Mercury Sable
When I open shower door after I have finished shower. Water from inside door goes on the floor, is there a catch all for the water
If the doors where installed correctly... the lip should be on the outside so that the water cannot run out onto the floor but runs into the shower instead...
heatman101
Apr 22, 2010 | Maax Shower Drain 10000041-105
2006 mustang water leaking rear floor
Hi , Its leaking water on the passenger rear floor? It could be the heater core leaking and running down the floor board to the rear of the vehical. Do you smell antifreez or see moisture build up on the windshield ? does the car seem more "humid" inside?
Jan 23, 2010 | 2000 Ford Mustang
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Water seepage at the bottom or floor of freezer. Water drips on the bottom floor of freezer, freezes, then ice build up.
You will want to check the rear of the fridge. There is an access panel there you can remove. Once removed, you can then check the drain hose and evaporator tray. There should be some water in the evap tray, if not, then the drain hose is plugged and causing water to run on floor.
Nov 10, 2009 | Cars & Trucks
Whirlpool frig won't fill the ice maker sounds like running but no watersomeing into it
If you hear the sound of water at the end of the harvest cycle, verify the plastic water line on the back of the refrigerator has not come out of the fill tube or water valve. Aslo verify it is not cracked and leaking. If so, water would be running onto the floor and damage to the floor could result.
Sep 11, 2009 | Refrigerators
Water on floor under front of fridge
CHECK AT THE BACK OF YOUR FRIDGE IF THE DRAIN PIPE IS STILL ON THE COMPRESSOR. ON TOP OF THE COMPRESSOR THERE IS A BUCKET WHERE THE WATER FROM THE DRAIN PIPE RUNS IN. THE HEAT OF THE COMPRESSOR CAUSES THE WATER TO EVAPORATE.
Sep 07, 2009 | Refrigerators
Water on floor when running, but hoses aren't leaking
never fear i to had this problem and by simply closing the door the water doesnt go on the floor. happy washing mr fixit.
Apr 26, 2009 | Washing Machines
Water Leaking on floor.
probably the water dispenser valve.
Apr 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
