Question about HP DeskJet 6450 Printer
Have a problem with printer- message PAPER JAM have checked through out printer no paper in system-- need help
  • 2 more comments
  • arj223 Apr 16, 2009
    Kevin-I did try your solution but it did not work- what is the next option
    Arnold
    Kevin- model number hp officejet j6450 all in one
    yes there was paper jam but it seem to only due to alignment of paper becuase there was no paper stuck in the cartiridge?
    Hope this helps
    Arnold
  • arj223 Apr 17, 2009
    Any updates on printer problem
  • arj223 Apr 18, 2009
    I still have the problem- clean out the system as directed- reset and still get the paper jam message
  • 148 Answers
Maybe it'll be better to perform these general throuble shooting steps:
General Trouble Shooting Practices for Printers and Cleaning Instructions:
  1. Isolate the issue: Are you getting power to the device, is it a feeding/paper issue or is it related to the software. To test this unhook the computer and reset the device. Try and print a configuration page using the printer menus.
  2. Other wise, diagnose the software: If no hardware issues appear after disconnecting the printer. Uninstall the printer before hooking it back up, remove any software associated with the printer, and then plug the printer into a different USB port on the PC. Reinstall the software using downloads from the vendor website instead of the CD whenever possible.
Cleaning the Printer:
Clean the glassy edge of the toner cartridge on laser printers while manually turning the gear to the side, on ink printers clean the base of the carriage and the copper contacts on the cartridge. Blow out around the access panels with compressed air and look to see if the rollers are getting really dirty or feel slick. If they do use a product like Rubber renew to make them tacky again or use a reconditioning kit to replace them.
  • When dealing with large bundled gear assemblies that are not close proximity to the paper I also like to spray a little WD-40 on the assembly, it reduces plastic dust from the gears and makes the printer run quieter.
I hope this helps. If not, please post your feedback here so I can help. Have a nice day.
Posted on Apr 17, 2009
  • Erinc INCI
    Erinc INCI Apr 18, 2009
    I know that your printer's model number is not below, but can you try these steps according to your buttons. These are some of the HP message resetting steps. I hope one will effect your printer and you error message will be gone. Also, did you try uninstalling/installing your printer driver again? Have a nice day.
    HP 4000/4050/4100/5000 Printers:
    1. Turn the printer off
    2. Hold down the left side of the ITEM and VALUE +/- keys, turn the printer on and wait until RESET MAINTENANCE COUNT is displayed and then release the keysHP 4500/4550 Printers:
    2. Hold down the CANCEL JOB and SELECT keys and turn the printer on, then wait until the display goes blank and the three LED's come on
    3. Press the right side of the MENU key, then press the SELECT key
    4. You will enter SERVICE MODE after the normal test completes
    5. Press the ITEM key until the FUSER MAINTENANCE COUNT appears
    6. Press VALUE +/- to change to zero
    7. Press SELECT to save
    8. Press GO; the printer should return to READYHP 8000/8100/8150 Printers:
    1. Press the MENU button until the display reads CONFIGURATION MENU
    2. Press the ITEM button until the display reads SERVICE MESSAGE = ON/OFF
    3. Select OFF*
    4. Press SELECT to save
    5. Turn printer off
    6. Hold the VALUE MINUS and ITEM MINUS buttons while turning the printer back on Hold buttons down until display reads RESET MAINT/COUNT and then release both buttonsHP 9000 Printers:
    2. Press and hold the CHECK key
    3. Power on the printer
    4. Release the CHECK key after all three lights come on The display should read SELECT LANGUAGE
    5. Press the up arrow until MAINTENANCE KIT is displayed, then press the CHECK key again and the maintenance kit count has been reset
  • Erinc INCI
    Erinc INCI Apr 20, 2009
    Hi, could you manage to reset your printer's error message?
    Genius:
  • 1,847 Answers
Unpluge the printer from the wall, take the ink cartridge out and roll the roller with your hand and look for small bits of paper. I am sure you will find a small one there.
Once done, put back the ink and restart the printer and let me know the status.
Thanks
Kevin
Posted on Apr 16, 2009
  • Legin Varghese
    Legin Varghese Apr 16, 2009
    Let me know the model no. and also let me know if there was any actual paper jam or this error came for no reason?
    let me know ....
    kevin
  • Legin Varghese
    Legin Varghese Apr 17, 2009
    If issue
    still persist and you see no paper that is stuck in the printer
    it's likely your printer is experiencing another hardware issue the paper sensor seems not working.
    I still want you to check for bit of paper with a flash light as there was a paper jam that happen.
    Follow this link..
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    I suggest contacting the printer repair guy and replace the paper sensor, that will fix the issue.
    Thanks
    Kevin
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
Papaer jam "check duplex"
Here's an article in the Lexmark website on Paper Jams and the Printer Displays a 'Check Duplex' or a '23x' Type Paper Jam Message: Lexmark T650, T652, T654, or X65x Series Printers. Just click on this link: http://bit.ly/aqGjtK. Read the instructions thoroughly. Hope this helps but if you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 25, 2010 | Lexmark T652DTN MONO LASER PRINT Printer
Lexmark X6570 printer - Cleared paper jam. No paper scraps visible anywhere in printer. Continue to get error message to clear paper jam and then press the "check" button. Does not reset. ...
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Nov 11, 2008 | Office Equipment & Supplies
HP OfficeJet 6110 All-In-One
go to hp.com, support and troubleshooting, type in your pirnter model number and download the user manual. follow the direction to disassemble the printer. you might not need to disasseble the printer, if you can see the jammed paper.
follow the direction and clean the roller and the printer head.
it should work.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper jam message
Check to see if you have a door in the back of the printer. Your jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 29, 2007 | Canon PIXMA MP470 All-in-One Printer
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
Nov 06, 2007 | Canon i860 InkJet Photo Printer
HP DeskJet 6450 Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
