Question about RCA HD52W56 52" Rear Projection HDTV
Rolling screen The picture on my TV keeps rolling vertically. It will stop and out of the blue the picture will roll on and off for several minutes. Not quite sure what to do and I don't want to mess it up any worse than it is already. Thanks
    Problem Solver:
  • 17 Answers
This may be a vertical hold control problem I'm not sure where the Vert. Hold potentiometer is on the mainboard. I would see if you can find someone who can locate it and adjust it.
Posted on Jan 27, 2008
My picture keeps rolling
Vertical sweep problem. Check vertical output section circuits to rectify this fault.
May 05, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Screen rolls maybe vertical sync
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
Mar 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
When viewing images on TV the picture is vertically rolling.
Check the video setting in the set-up menu. It may be set to PAL if you are on the NTSC system, or vice versa. Also check the TV input to ensure your're on the correct channel.
Mar 02, 2008 | Canon PowerShot S2 IS Digital Camera
Tv roll
Are you sure the roll isnt Vertical? as if it is then all you need to do is adjust the VERTICAL HOLD PRESET POT which should be located on the PCB somewhere, its very unusual for TV.S to roll horizontally as then the picture just goes out of sync. and you would not see a picture at all. When you find the pot turn it ( with a small screw driver) slowly until the rolling stops, if it does not stop then you have a faulty component in the vert. sync. circuitry.
Feb 04, 2008 | Televison & Video
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Akai DHT300 screen rolling
The picture is rolling because there is no sync signal in the composite output. Are you using the RCA jack or the S-video output? Is there another small TV you could hook up for a test to see if the problem appears there? If it does, then the Akai has the issue and needs to be examined further. If not, the TV input may have an issue. You didn't say what the TV is but there is the possibility the video input is looking for external sync from the DVD but that's a bit of a stretch. Can you feed a different source into the video input of the TV to see if you get the same result? Hope this helps.
Nov 01, 2006 | Akai DHT300 System
RCA HD52W56 52" Rear Projection HDTV Logo
211 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
