Question about Uniden TRU348 Cordless Phone
Caller Id I see my phone number when I receive a call, not the number from caller, I try with other caller id phone and read fine, but my unidem tru348 read always may number in the lcd screen. Can I fix that?
SOURCE: caller-id quit working
This is a followup to my earlier suggestion. My caller id is working. So, the culprit had to be related to the 9V battery. Just try my earlier solution from 1/20/07. If it works..fine. If not, bye-bye to the phone.
Posted on Feb 10, 2007
SOURCE: Uniden CallerID not working..
sell it off
Posted on Jun 17, 2007
  • 65 Answers
SOURCE: caller id
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
Posted on Feb 02, 2008
SOURCE: Caller ID Problem on the GE2811 Twin cordless phone system
Still have not been able to solve the problem of having inconsistent caller id display when the telephone rings
Posted on Mar 24, 2008
  • 32 Answers
SOURCE: caller id
Caller ID in the USA uses the FSK standard. For the most part, caller ID in India uses DTMF (although I have heard of some FSK usage).
I am currently living in New Delhi and have an Airtel home phone line. My switch uses DTMF. I went to the Palika electronics bazaar (I aways use shop number 266 near gate 5, they seem to be a little kinder to foreigners as far as the "final price") and purchased an DTMF to FSK convertor. My US phones now show caller ID information, although using US number seperations ### - ### - ####. I paid R500 but you could probably get it for around R400 if you are willing to put in the time bargaining. It looks like they are also available on Indian Ebay.
Mine says UST001B. It looks like these are low volume items because they stuck the components into a box marked "DSL Splitter" It works to convert the caller ID as advertised.
Posted on Sep 07, 2008
SOURCE: Need manual for Innovage Talking Caller ID LCD Touch-Panel phone
I've got a manual I scanned for Product ID is 1604007. The origianl manual is printed in really small letters. The scan is in adobe format now and can be seen pretty good when set to 125%. I just need to know where to upload it.
Posted on Sep 25, 2008
0 characters
1 Points
How do I unblock my phone number
After you enter *67, you hear the dial tone. Dial the outbound number. Your caller ID is not presented on the receiving end.
After you enter *82, you hear the dial tone. Dial the outbound number. Your caller ID is presented on the receiving end.
Sep 25, 2014 | Phones
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
Caller id is not displaying. but displays on our other phones. date/time work, phone plugged in fine. other suggesitions? is there some type of #'s I need to put in to get it to working again?
If this is a stand alone analog(not connected to phone system) telephone, check for batteries. If the phone is connected to a phone system, the phone must be set to ring to receive caller ID. If neither suggestion helps, please send model number of phone and model number of phone system if there is one.
Jan 23, 2011 | Meridian Corded Memory Speakerphone with...
I just received KX-T7730 phone with an LCD screen and it is not showing the caller ID # that is dialing in. It only displays CO 1. The previous phone similar to KX-T7730 shows the caller id #. So how can I...
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
Hope his help and rate please.
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Aug 16, 2009 | Uniden Cordless Phone
Nortel M7310 Display Caller
In system programming your station needs to set caller id to Y.
i am assuming the system accept caller id. Other stations are working.
Jun 22, 2009 | NorStar Meridian M7310 Phone
Caller ID Stopped Working
I had the same problem - until today. Seems that the phone jack wiring in my living room needs repairing. Receiving and making calls is no problem, but the Caller ID is first to go (according to phone service provider). I tried out the phone in the bedroom, and the Caller ID shows up fine. Serviceman coming tomorrow to fix the L/R wiring.
Jan 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Uniden TRU348 Cordless Phone Logo
24 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
