Question about NorStar Lands Phones
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
  • Jerry Yamakoshi Apr 15, 2009
    haven't found the interval time. The problem still exist because when I press feature 981 the message to me is still pulsing at the one second level
    when I go to feature 981 the voice instruction also pulses at the 1 second interval half on and half off. The half off produces white noise (hissing sound)
  • 11,896 Answers
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Posted on Apr 15, 2009
  • Nate Stansfield
    Nate Stansfield Apr 15, 2009
    Here is a link to tons more programming instrucitons:
    http://www.telephonemagic.com/phone-supp...
    New Friend:
  • 79 Answers
THIS WILL BE DUE TO THE SETTING HAVE A LOOK THOUGH THE MENU YOU SHOULD BE ABLE TO ALTER AND CHANGE THE LENTH OF THE RECORDING TIME
Voice mail locked after various attempts at putting wrong password in. How do I rectify?
Your mailbox is assigned a maximum number of incorrect password attempts.
Norstar Voice Mail records the number of incorrect attempts from the last time your mailbox was successfully accessed. Once the number has been passed you are"locked-out" Your mailbox cannot be opened again until the System Coordinator resets the password
Oct 22, 2013 | NorStar Meridian M7310 Phone
Trying to change the number of rings before my phone goes to Voice Mail on the Meridian (Nortel) M5316. Only two rings currently so I miss a lot of calls. Thanks!
Depending what system your provider is using it can either be done by you at home or they will have to set it. If you call your provider they will help you or they will fix it. Each ring is set at 6 second intervals so if you have 3rings that is 18 seconds. If you was 6 rings then ask for 36 seconds etc. hope this helps
Oct 11, 2013 | Aastra Telecom Aastra MDC Centrex...
I have a Meridian nt5b01 phone system with 8 handsets hooked up. when I try to add hookups for additional handsets the set I'm testing with will never quit blinking. Any clues what could be the problem? I...
I need to upgrade meridian NT5B01, is it possible to add voice mail or others, please give me the items that I can upgrade my system with insted of changing it
Nov 11, 2010 | Nortel Meridian M7208 Corded Phone
Voice mail message will not change
Press the table button then enter in table 1
Jun 25, 2010 | NorStar Meridian M7310 Phone
Feature Button
Sounds like the voicemail either is disconnected from the phone system or has lost power to the voicemail.Open the cover to the voicemail and see if there are any lights on in the system.If so then disconnect the power tho the voicemail for about 30 seconds. the voicemail could take up to 10 minutes to fully reboot.
Feb 26, 2010 | NorStar Meridian M7310 Phone
I have M7310 phones with the complete system I can not seem to be able to activate our mail box system, we tried entering f:981 and F:983 however it says feature inactive
If none of the voice mail feature codes work (feature 980-989) then the voice mail system is either not working or isn't recognized by the telephone system.Go to your communications closet and check to see if theres a power light on in the voicemail.If not then you might want to call in your tele system service provider.
Jan 15, 2010 | NorStar Meridian M7310 Phone
Voice mail greeting
When you log into the mail box, option 8 will be for personal options. Then option 2, will allow you to record your personal greeting. If this is a Startalk vociemail.
Mar 11, 2009 | Lands Phones
Voice mail
try rebooting the phone system.
Jun 02, 2008 | NorStar M7324 Telephone
Meridian M7310 phone system
We had a tech come in who has worked on the system a long time ago and he said because of the power surge it fried the Star Mini. He said they are hard to get and may have to search on Ebay. We only had a battery backup instead of a UPS.
So for now we are without voicemail.
Mar 17, 2008 | NorStar Meridian M7310 Phone
Lands Phones Logo
1,405 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
