Question about Dell 922 All-In-One InkJet Printer
Paper will not feed correctly,,,it pulls off center and then jams
  • bonnie290 Apr 22, 2009
    Thanks...did as you suggested and a button fell out. Fixed the problem, now just have to figure out where this button came from!
    Problem Solver:
  • 7 Answers
You have something jammed in the paper path of the printer. Un plug it, remove the paper, and turn it upside down. Something will probably fall out. If not, shine a flash light down inside and look. It's most likely a paper clip or something. This is a common problem with those type of feed systems.
Posted on Apr 17, 2009
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    How to clear paper jam copier printer
    The message Paper Jam may appear on the display if the Brother machine is not feeding paper correctly, paper scraps have become stuck in the print head path, the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
    To resolve this issue, please follow the steps listed below:
    1. Disconnect the machine from the power supply.
    2. Turn the unit around and remove the Jam Clear Cover from the back of the machine by grasping it at the Center and pulling it straight away from the rear of the machine.
    3. Look for any paper scraps, jammed paper or foreign objects in the rear of the unit. If anything is found, remove it. Be carefull not to touch the feed roller.
    3. Remove the paper tray feeder from the front and look inside for bits of paper and check the paper is flat in the tray.
    4. Replace tray and back cover and all should be fine.
    rover620
    Sep 21, 2010 | Brother DCP-330C All-In-One InkJet Printer
    Unable to clean 51
    If there is no jam it is generally a mechanical issue such as...
    1. The planetary arm assembly not engaged correctly
    2. Ink cartridge/purge switch harness not connected correctly
    3. Purge cam switch broken
    4. Gear(s) on maintenance unit broken
    5. Paper feed motor broken
    6. Main PCB defective
    I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
    You will need to visit your local Brother Authorized Service Center, you can find one by clicking here. Thank you for using FixYa! - Don't forget to rate our service.
    Feb 02, 2010 | Brother Office Equipment & Supplies
    Screen says
    I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything! You will need to see an authorized service center for repair.
    Jan 27, 2010 | Brother MFC 210C All-In-One InkJet Printer
    Paper pulls to the right, jams, won't print, tried different paper still won't print
    Sounds like the feed rollers need cleaning.
    Clean the feed rollers, lint free cloth,bottled water.
    wait for them to properly dry
    Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
    Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
    Check paper size is correct in print properties too.
    Should be good then
    Try print.
    Regards
    Richard.
    Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Printer will not feed paper correctly
    there were may situation that can help with this trouble,
    1- try to see if the trays are seated correctly no bend or twisted
    2- try to check the quality of your paper no concave nor convex ( like U or N)
    3- clean the feed roller from either side by moistened cloth, ( only on one direction evenly
    4- ensure no hindrance on the paper path inside the machine
    5- reset the unit once more
    let me know if you need some more
    Jul 25, 2008 | Office Equipment & Supplies
    Paper wont feed then says paper jam
    Got rid of my problem!
    In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
    Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect)
    Apr 08, 2008 | Dell 924 All-in-One InkJet Printer
    Paper jam
    I too have this infuriating problem and the reason has already been pinpointed very well it is indeed the front rubber pinch cam not grabbing the paper well. I have approached this problem from another angle... under the front sprung loaded flap on the paper tray
    there are two compression springsapprx 1/2" in dia. Gently prise apart the 2 flap pivot (on the extended arms) to gain access to the springs ,pull out the springs and either replace them with slightly stronger ones or pull the existing springs apart to retension them and pop them back (long-nosed pliers or tweezers) this will restore the spring tension lost during use with the rubber pinch cam.
    Jabba0737
    Mar 10, 2008 | Samsung CLP 300 Laser Printer
    Paper feed skews right and jams
    Mine is also doing the same thing. Very frustrating!
    Jan 02, 2008 | Lexmark X75 All-In-One InkJet Printer
    Dell 922 All-In-One InkJet Printer Logo
    127 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
