Question about Thermador C272 Electric Double Oven
Self-clean turns off after 5 minutes with F2 error message
The self clean feature of my Thermador built-in oven, model sc301, turns off after about 5 minutes with an F2 error message. I have not used the self-clean in a few years - I don't bake too often.
  • 794 Answers
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 04, 2011
I have a Thermador Model SC301TP wall oven. When I try to Self Clean I get error F2 which I think is that it is a tempature issue. What should I do?
either the oven sensor is bad or see if the pins where it connects on the relay board have bad solder joints. re-solder first, then replace if needed.
Jan 18, 2015 | Thermador Ovens
F82 error
door switch not sensing properly or a bad power relay board.
Oct 01, 2012 | Thermador Ovens
We set our wall oven for self-clean and received an error message after about 4 hours that told us to turn off the circuit breaker. We are unable to turn the circuit breaker back on again.
If you cannot turn the breaker back on then it is no good...some breakers do take some very firm effort to get them to come on...but the oven may have ruined the circuit breaker...
Circuit Breaker Keeps Tripping
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 26, 2010 | Thermador SC302T Electric Double Oven
How do i self clean
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following products. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: Thermador� Built-In Ovens
Units: About 37,000 (42,000 built-in ovens were previously recalled in June 2007)
Manufacturer: BSH Home Appliances Corp., of Huntington Beach, Calif.
Hazard: The ovens can have gaps in the insulation where overheating can occur and when used in the self-cleaning mode it can cause nearby cabinets to catch fire. This poses a fire hazard to consumers.
Incidents/Injuries: BSH Home Appliances has received three additional reports of incidents, including two that resulted in fires that damaged surrounding cabinets. No injuries have been reported.
Description: The recall involves Thermador Brand built-in double ovens with model numbers C272B, C302B, SEC272,C301U, SEC302, SECD272 and SECD302 and serial numbers between FD8403 through FD8701. Model and serial numbers are located on the underside of the control panel.
Sold at: Appliance and specialty stores nationwide from June 2004 through July 2007 for between $3,000 and $4,400.
Manufactured in: United States
Remedy: Consumers should immediately stop using the oven�s self-cleaning mode and contact the firm to schedule an inspection and free repair, if necessary.
Consumer Contact: For additional information, contact Thermador at (800) 701-5230 24 hours/day, 7 days/week, or visit the firm�s Web site at www.thermador.com
Dec 05, 2010 | Thermador C301U Electric Single Oven
How do I use the 'self clean' feature? I can't find the manual and it needs to be done
Good luck with that - whenever we use the self-clean function it goes crazy on us - beeping, error codes - door locks up - have to reset breaker to make it shut down. The last time the door got permanently locked - nightmare!!
Also, there is a recall on some of the wall units - ours of course isn't part of that recall - Thermador doesn't care that we can't open our oven - they'd rather you purchase another piece of junk!!
Oct 20, 2010 | Thermador SC302T Electric Double Oven
What is error code F34 on the thermadore built in double oven
If your Thermador was manufactured between 2004 and 2007, this may be due to a recall issue. I kept getting this error on my Thermador wall oven when I would run the self-cleaning feature, and when heating it over 375 degrees. After doing some research, I discovered that my oven was recalled. Apparently there are gaps in the insulation which could cause a fire. You can find out more on the Thermador website: http://www.thermador.com/safety-notices/7_oven-safety-recall-notice-expanded
Oct 15, 2010 | Ovens
Oven door remains locked after self-cleaning
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 27, 2010 | Thermador SC302T Electric Double Oven
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
F2 error message
Hvace, F2 is a shorted temperature sensor. Probably took it out with the self clean...Catriver..post back.
Aug 31, 2006 | Whirlpool GBS307PD Electric Single Oven
Thermador C272 Electric Double Oven Logo
520 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
