Question about Visonik V117SX Car Audio Amplifier
VB101PK REV 13, AMP WITH SUBWOOFERS
PROTECTION LIGHT CAME ON AMPS. I TESTED SPEAKERS IN ANOTHER CAR THEY WORK, BUT I CANNOT GET PROTECTION LIGHT OFF. I DISCONNECTED EVERYTHING AND RECONNECTED. THEY WERE WORKING FINE, BUT WHEN I DISCONNECTED SPEAKERS TO MOVE THEM OUT OF TRUCK AND PUT THEM BACK, PROTECTION LIGHT CAME ON. dOES IT HAVE TO BE RESETTED OR WHAT DO I DO?
  • dvjk
    dvjk May 26, 2008
    sdfgfdf
  • ebby_bishop Mar 09, 2009
    i have everything hookedup speakers and the amp. but protection light comes on not the power at all what do i do??
Was the amp hooked directly to the box? You probably rattled the power connections from the circuit board like I did on a PT 800 watt amp.but check amp fuses first.
Posted on Sep 16, 2007
You may have to much speaker for the amp or one of ur wires could be crossed
Posted on Mar 17, 2008
SOURCE:
Stopped working. Power light is on. Could it be a fuse? Can I change it myself? Is there a lifetime warranty?
Amp has power, but no sound! - ecoustics.com
www.ecoustics.com > ... > Archive through November 13, 2007 Forum
Nov 5, 2007 - The other night my fiance's amp stopped pushing the subwoofers. ....also, it was working fine for however long- and then just stopped working. if that were the case, it wouldn't have worked in the first place. .... lastly before u go saying but the amps power lights on i'm sure the amps ..... Car Speakers Forum WHY DOES MY AMP POWER LIGHT TURNE RED ON PROTECT ...
Sep 11, 2011
Please someone help me! I am dying without my music!!!
Aug 4, 2011
Subwoofer stopped working all the sudden
May 26, 2010
More results from www.ecoustics.com
Jan 18, 2016 | Audio Players & Recorders
PROTECTOR LIGHT STAYS LIT ON THE AMP, NOT POWER LIGHT
The protect light is on because there is a internal problem with the amp, causeing it to over heat,
Dec 02, 2012 | Audio Players & Recorders
Music just stop working. Now it flashes 'protect' and won't play. Wat do I do?
It sounds like there is a problem with your wiring. Usually the protect on an amplifier comes on when your amp is overheating. The overheating is usually caused by the wrong impedence, or not engouh air circulation. If you have a digital multimete (DMM), you can disconnect the speakers from the amp and measure the impedence. If you do not have one, you should take it to a local car stereo shop. They would be able to test this area for you. If they tell you that you have to buy another piece of equipment, please post the make and model for your amp(s) and subwoofer(s). This also goes for replacement factory speakers.
Jun 28, 2011 | Kenwood Car Audio & Video
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
How do i get my kicker 500.2 protection light off
the protection light will come on as a saftey precaution in case the spearker blows or a wire shorts and in some cases if the amp it self shorts check your wiring and if you find nothing take the amp to a auido place and have it tested.
Oct 03, 2010 | Car Audio & Video
No sound from amp when amp is powered up, whats wrong? Alpine m-1000 wih alpine deck. Was told something about resetting it but don't know, please help?
There is a number of things that can cause no sound from the amp.
Check to make sure your RCA's are plugged in to the amp.
Make sure the ground and remote are not touching on the amp.
This will cause your head unit to gray out in some areas.
Verify, your subwoofers are in working order.
Test another pair of speakers on your amp to make sure.
If those speakers work, your subwoofers are fried or have come unhooked inside your subwoofer enclosure.
Make sure you have not set the head unit to Surround Sound if you have a DVD player in your vehicle.
This should be set as passive.
Make sure your gains aren't turned down on the amp.
MAKE SURE YOU DIDN'T BLOW A FUSE UNDER THE HOOD.
Even if there is a light on the top of the amp, the fuse might have blown.
Make sure a fuse on the amp didn't blow. This will in some cases cause the amp to go into protect and no bass.
Jul 27, 2010 | Alpine MRD-M1000 Car Audio Amplifier
Lanzar MAXP84 subwoofers problem
Unplug your subwoofer speaker cables and then turn the vehicle back on, and if the protector light turns off it is your woofers.
If it is still on, it could be a bad fuse going to your battery, a bad fuse on the amp, or a bad amp. :)
Nov 10, 2009 | Car Audio & Video
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Amp problem
could be one side of spk voice coil bad if they ar dualor rca problem
Mar 29, 2009 | Blaupunkt PCA465 Car Amp
I have an older red sony xplod 500w 4ch amp. the power/protection light is glowing red. what does that mean and how do i fix it? I have no sound.
The protection light comes on if the amp overheats or if the speaker outputs are shorted.
Turn everything off and check all of your speaker wires for shorts. When you locate and repair the short, the protection light should go out and your amp will work normally again.
Hope this helps!
Mar 26, 2009 | Car Audio & Video
Visonik V117SX Car Audio Amplifier Logo
727 people viewed this question
Top Visonik Car Audio & Video Experts
Mike Duncan
Mike Duncan
Dalynn Turner
Pierre Laplante
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
