Question about Mtd 22" Yard Machine Push Mower
Replace pull rope
I have a Yard Machines push mower, 6.25 HP Engine (BS). Do i have to take out the pop rivits to replace the rope, or is there another way?
  • 205 Answers
Yes, take the shroud off that the recoil is riveted to
Posted on Apr 15, 2009
I have a 46" Yard Man riding mower with 20 hp BS.
Hello, Ask your local Mower shop if they show a Thermal switch for the PTO. You may have to replace it or move it away from the heat.
Aug 14, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
How to replace the broken pull rope
The link below will go over the process of replacing the rope on a briggs mower (process will be similar to your engine for basic idea)
http://www.youtube.com/watch?v=iczCZaRiR0Q
If your starter is bolted to the fan cover it will be easy to remove the rewind and install the rope. If rewind is rivited to fan cover, pull off the fan cover or cut the rivets and then install new rivits (not enough space to use nut with bolt to hold rewind due to close proximity of flywheel). Post agan if you have other questions. Dont worry, easy repair.
Aug 11, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
How to replace coil string
This is best done with two people. Remove cover, place down so you are viewing the rope pulley. Remove all old rope. Measure 8 foot of new rope. line up pulley rope hole with rope opening in cover. Wind rope pulley 6 turns. Push new rope thru both rope openings, one in pulley and one in cover. Pull rope thru pulley and cover. Tie knot in pulley end of rope, Slowely release rope so it rewinds onto pulley. Install hope handle, your done. was'nt that easy? You will have extra rope, this is needed to go from engine to handle support on your mower handle.
May 28, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
REPLACE PULL CORD
the part that's riveted to the motor isn't to come off. You need to take the flywheel cover off; that't the whole thing, and it's held on by 3 bolts. Once that's off, you can get to the nylon pulley. easiest way to do this, is to take the screw out of the center that holds the pulley in, gently lift the pulley out just enough to get a hold of the rope, thread it back through the hole, and put the pulley back in place. Then pull the rope all the way out, and hold the pulley once it's out. you can then either pull it out from the knot inside the retractor, or you can cut the knot off, and pull the rope out. now, you want to turn the pulley the same direction that the rope pulled it out, until it gets tight. Back it off enough that you line up the hole in the cover with the hole in the retractor where you knot the rope. push your new rope through, tie a knot in it, and take up the slack. now you can let go of the retractor, and let it pull the new rope in. when it's done, put the cover back on, measure out the new rope to end up at the holder on the handle, and cut it and put the handle on the rope.
Mar 29, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Lawn mover will not start, was flipped over
The clicking noise may be the blade hitting the side of the mower or it was not put on properly. It needs a balance to the aluminum flywheel on top of the engine. The blade adapter and blade provide this balance for the engine to run.
Good Day.
Oct 07, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Replacing the pull rope
The solution to this one is very tricky. You have to remove the shroud to access the inside of the spring return. Pull the rope out but make sure it is still attached to the spindle check to see if the return spring has broken. If it is then it will have to be replaced.
Jul 27, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Pull rope snapped on my Yard Machines 4hp 22in push mower
There should be 3 -3/8 or 7/16" bolts on the side of mower (where the spark plug is, there should be one) the other two will be just opposit of the two. Remove bolts and housing should be free.You might to remove any cables to free up any slack.
Jun 09, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
358 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
