Question about Dewalt 2 Hp 4 GAL Air Compressor
I need motor brushes for campbell hausfeld WL611105AJ air comp.
One of the brushes in my electric motor fell apart. The numbers on the motor are MC030100AV
LR40116 120V 60Hz
NL 745538
Thermal Protection
Do you know if I purchase new motor brushes so I don't have to buy a new motor or a new compressor?
Thanks
RPugh
  • 530 Answers
If you can find a match to the brushes that came out of the motor they will work. When I say match, I mean the size. Height, width and depth, length only needs to be close to allow for wear over time. The longer the brush the more wear you will get. If you can't find the exact size then you can always file a larger brush to fit. I just had to do that for a small motor in my shop-vac, works great. Also another consideration is how the line coming off the back of the brush connects to the Stator. If you can't match the connector soldering it is fine or crimp the appropriate connector to it. Beyond those two elements brushes are pretty much the same.
Your biggest problem is finding an assortment of brushes. Some hardware stores will carry some, (check the bins with all the small nut, bolts and other connectors), also automotive parts stores carry them, (for alternators),. Your best bet would be an electric motor repair shop.
Good luck
Posted on Jun 11, 2009
Campbell Hausfeld Air Compressors motor shoots fire
You may have a short in the motor itself. You may need to have the electric motor checked. It could be dangerous to continue using .
Apr 23, 2012 | Campbell Hausfeld 3/8 in. NPT Compressor...
Where to find replacement carbon brushes Campbell Hausfeld pressure washer pw1350
Parts for Campbell Hausfeld can be found at www.chpower.com. Campbell Hausfeld does not however, sell motor parts for many of their tools. You would have to call their 800 number and speak with a parts person to determine availability. You may be able to purchase a close match at a local True Value hardware store. They sell a variety of brushes for many major brands of tools. Purchase a slightly larger set of brushes and sand them to size. If the connector is different, cut off the old connector and solder it to the new brush.
Dec 15, 2011 | Campbell Hausfeld Garden
Im trying to find brushes for my electric motor in my husky air compressor mod# 417-270
I have not been able to find brushes for your type of compressor. I find a close match on ebay and shave/sand to size. Measure your brushes. Search ebay for "carbon brushes" looking for best price and size needed. Make sure that the armature is still good because the brushes will wear very fast if arm. is bad. Good luck
Feb 13, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Dosent start. motor dosent hum or anything but I am getting current to the motor
How old is it and how many hours are on the motor? From the very little info it sound like the motor needs to be taken apart and the brushes replaced.
Jan 10, 2011 | Campbell Hausfeld Air Tools & Compressors
I have a campbell hausefield vs series air comp and when it reaches full air supply and shuts off air leaks (alot) out of the switch i replaced and nothing changes.
There is a check valve on the tank where the line from the pump goes to. It should also have a smaller line running to the pressure switch. If the valve or spring inside is broke or stuck it will leak as you describe. You need Campbell Hausfeld part number CV221502AJ.
Dec 22, 2010 | Campbell Hausfeld 5HP 26 Gallon Single...
Campbell hausfeld wl504100aj parts?
Campbell Hausfeld uses two sets of id numbers. One number identifies the complete unit and a second number usually identifies the pump unit. Look for second number under cover on pump. Parts are available at www.chpower.com
Aug 09, 2010 | Makita MAC5200 Electric Powered Air...
Electric compressor will not start up im getting power thru the switch but comp.doesnt attempt to start.
your pressure switch is defective that controls the cycling of the motor,its fed air pressure off the tank line and opens and closes contacts to start and stop the motor to build air pressure when needed
Jul 17, 2010 | Campbell Hausfeld 26 - Gallon Air...
Electric compressor motor problem
Unloader valve on switch. That switch is not bleeding off cylinder head pressure,when it shuts off.
Apr 06, 2010 | Campbell Hausfeld 26 - Gallon Air...
Campbell hausfeld paint sprayer has no suction
The same thing happened to me before if the paint is too thick. Another reason was when the gun toppled over and paint went into the spring and needle in which case you will have to take it apart and clean it.
Oct 18, 2008 | Campbell Hausfeld Air Tools & Compressors
Dewalt 2 Hp 4 GAL Air Compressor Logo
1,347 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
