Question about Dryers
Dryer will run for a couple of minutes and will stop/ Pops the fuse. We are getting the Power failure code. Kenmore Elite Smartheat quiet pack 9
  • 221 Answers
It sound's like the motor might be going bad, the dryer motor may be drawing to much current during operation causing the fuse to blow, check the motor to see if it spin's with little or no resistance, also turn the drum by hand to make sure it spin's freely, or it could be a short in the wiring that's causing the fuse to blow, check the wiring for a frayed or damaged wire, or for a wire that may be making contact with the shell of the dryer.
Posted on Apr 15, 2009
Kenmore Elite Smartheat Quietpak 9 Dryer won't turn on.....as if there is no power. After being unplugged for a while, it will run one cycle.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 22, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
MY DRYER IS NOT LIGHTING SO THE CLOTHES WILL NOT DRY....IT IS A KENMORE SMARTHEAT HE4 QUIET PACK .......
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite Smartheat quietpak9 model HE4, keep turn off after 15 to 20 minutes, it does getting hot. Could you please let me know what will be a problem. I bought it used so I am not sure how old is...
might need a clean out keeping heat inside of dryer,or you have abad motor,take the vent line off the back of dryer and run it to see if the block is in the vent line or in the dryer,also take off bottom panel,unplug dryer,take out lint filter and then remove the duct that the filter slides into,if it's blocked clean it out and you should be all set,usually the thermal fuse pops when this happens so that's why i say you could have a bad motor
Dec 15, 2009 | Kenmore Elite HE4 Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore smart heat quiet pak 9, just beeps won't start
m dryer did the same thing tonight and it was the door switch luckly i wiggled it and it came back on
Feb 22, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
78 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
