Question about Optoma H56 Multimedia Projector
How do I access service menu to reset lamp timer for Optoma H56?
Just replaced the bulb but the onscreen display keeps saying the bulb needs to be replaced. Need to reset the bulb timer.
Thanks.
  • Anonymous Mar 31, 2014
    Replaced the lamp following all the procedures but can't complete the last step of Lamp timer reset since the projector does not turn on for me to be able to access the menu. The projector goes through fan cycles and ends up with blinking amber on/off light as well as a red lamp light.
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Up
Up
Left
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Posted on Jan 28, 2011
How to reset the lamp timer for Sony Projector vpl-px32
    Instructions
      • 1 Turn on your Sony projector after replacing the lamp.
      • 2 Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
    • 3 Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
    Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
Jul 07, 2014 | Panasonic PT-44LCX65 Television
REPLACE AND RESET LAMP TIMER MESSAGE KEEPS APPEARING. I REPLACED THE LAMP. MESSAGE STILL DISPLAYING.
you need to reset tht timer,
I will tell you the way to reset the timer ,Pls let me know your projector's Medel.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Oct 27, 2013 | Panasonic Televison & Video
Timer display says "Lo Battery". I put two new
Intermatic timers might require reset-and-reprogram after battery replacement.
To reset, hold down on-off button and push reset button once.
Keep holding on-off button until display changes.
Release on-off button, and display should blink 12:00
Try cleaning battery carriage contacts with alcohol and make sure battery polarity is correct.
If functionality is not restored, then replace timer.
Intermatic EJ500 comes with 1 year limited warranty and is rated for incandescent light bulbs only.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Aug 08, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
Optoma hd65 has a red light. Only had it for 5 months. How do you fix?
The red indicator light usually comes on when something needs attention. Most often it has to do with the lamp timer or the filter timer. The projector keeps track of how long it's been since you've changed the bulb or cleaned the filter(s). You can reset these timers in the menu. Be sure to clean the filter before you reset the timer
May 31, 2011 | Optoma HD65 DLP Projector
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Our projector indicates that the light bulb needs to be replaced after replacing the light bulb once it still indicates that it needs to be replaced.
    This is the excerpt from the manual on how to reset the lamp life timer.
    Turn on the projector and use "Lamp Reset" after the lamp module is replaced.
    Lamp Reset: (i) Press "Menu" ?§ (ii) Select "Options" ?§ (iii) Select "Lamp settings" ?§ (iv) Select "Lamp Reset ?§ (v) Select "Yes".
    Jan 12, 2011 | Optoma HD65 DLP Projector
    XV-Z10000I change the lamp with a new one it doen't turn on ofter replacing with the bulb, does it need rest and how can be done Thanks Zia
    Reset the lamp timer.
    1,Connect the power cord.
    2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
    "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
    Have a nice day!
    We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
    Jerry
    Lampdeng Limited
    May 18, 2010 | Sharp BQCXVZ100001 Projector Lamp for...
    Still getting "Projection lamp is nearing end of life"
    KDF46E2000 - Change Lamp Warning - Reset
    Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
    Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
    1. TV must be in standby mode. (Power off).
    2. Press the following buttons on the Remote Commander within a
    second of each other:
    DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
    contains the Category with the Adjustment Item you want to change.
    2. To change the Category, press 2 or 5 on the Remote Commander.
    Note: Pressing 2 or 5 only changes the categories within the
    Service Menu displayed. To change a Category on one of the other
    Service Menus, press the JUMP button until the correct Service
    Menu is displayed.
    3. To change the Adjustment Item, press 1 or 4 on the Remote
    Commander.
    4. To change the Data Value, press 3 or 6 on the Remote
    Commander.
    Note: To go back to the last saved Data Value, press 0 then ENT
    on the Remote Commander to read the memory.
    5. To save the changes, press MUTING then ENT to write into
    memory.
    6. To exit service mode, turn the power off by pressing POWER .
    Wait 2 minutes before restarting the set to allow the fans to
    completely shut down or the Service Menu will appear on the screen.
    easyab
    ConvergenceRepair.com
    __________________
    Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
    Optoma hd65 projector new bulb wont turn on...cant reset timer!
    I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
    Jan 31, 2010 | Optoma HD65 DLP Projector
    Optoma H56 Multimedia Projector Logo
    1,407 people viewed this question
    Top Optoma Office Equipment & Supplies Experts
    jasbo
    jasbo
    color wheel light...
    Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
