Question about HP Pavilion a420n PC Desktop
WHEN I REINSTALLEDD MY HARD DRIVE MY MONITER SHUTS OFF HOW CAN I FIX THIS
  • Roberta Smith
    Roberta Smith May 11, 2010
    does it use a stand alone video card or the built in video ?
  • 227 Answers
Check to ensure you Video Card (and all other cards) are seated correctly in the slots. You may have knocked it loose when changing your drive.
Posted on Apr 15, 2009
Dell wont boot when pluged in it comes up for split second and shuts down green light on motherboard is lit
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a 40 pin flat ribbon type it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be
faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead can cause you problems
computers need power and data travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all power and data leads make sure they have secure dust free connections
cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease
hope this helps
Jul 15, 2012 | Computers & Internet
My hard drive clicks and the moniter turns off
Hi, you can isolate that problem to see what is the defective part;
1. Remove the hard disk connection from the board and its power then re-start the PC.
2. If the PC powers and initializes, then you can prove that the defective is the hard drive. If the same problem that it shuts down then. the next target is the power supply. If you change the power supply and it turns out success, then we have solved the problem, if not, next thing is,
3. Turn off PC, remove the battery/clear cmos, the memory and the processor for 20 minutes.
4, After 20 min re-install the battery, memory and processor. Without the hard drive when starting, lets see if it will boot without the O/S.
others, when you say the monitor turns off, does the CPU still working or not? Isolate also the monitor by powering it on and not attaching the communication cable to video port, lets see it the monitor itsel display by its internal video logo to be sure it is okay.
Jun 22, 2011 | Computers & Internet
My aspire 5100 turns on and shuts right back down
Hi
disconnect the power cable and remove the battery and then press nad hold the power button for a minute. then connect every thing back and then see if the screen comes on.
in case it does not then again remove the battery and power cable and remove the hard drive and ram and put it back in again.
and then check still does not work see if the screen comes on an external moniter, still if it does not come on call ACER if it is under warrnty they would give you free repair.
May 03, 2010 | Acer Aspire 5100 Notebook
Moniter shuts down while playing wow while not in windows mode
Go to your computer's Control Panel, Power properties, and change the power scheme to Always On, where hard disk shutdown, monitor turn off and system suspend are all set to "never". This should help.
Dec 26, 2009 | Xerox XA7-17i 17" LCD Monitor
Problem for Acer Aspire 5315 PC Notebook. This notebook will power up but nothing is happening on the moniter and even on a external moniter. I cannot tell if it is even booting as the hard drive light or...
have it check with the service center, the problem is no in your hard drive, or ram. or even your monitor, it has something to do with your video card, and you'll need to take out all to cover to get access to it, so I suggest better bring it to a service center to avoid more damaged
Nov 05, 2009 | Acer Aspire 5315 Notebook
My computer screen is blank on computer. have logitech ex110
Did you try moving your mouse? After a period of time of inactivity the computer will go in standby mode which can be a black screen.
Sep 28, 2017 | Logitech EX110 Mouse
Laptop wants to load up then shuts off
I would take into a computer shop and see whats wrong with it, sounds like a bad CPU Fan.
Aug 08, 2006 | Compaq Presario 1700 Notebook
HP Pavilion a420n PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
