Question about Gigabyte GA-8PE800 PRO Motherboard
GA-8PE800 HELLO PLEASE HELP ME MY GA-8PE800 BECOME IN FREEZING STATE AT POST AFTER SCANNING THE MEMORY WHAT WOULD BE THE PROBLEM AND ITS SOLUTION
    Sergeant:
    Champion:
  • 293 Answers
Re seat your memory and clean them.
Posted on Sep 15, 2007
It could be a hard drive issue.
    Scholar:
  • 136 Answers
First thing is to clear the BIOS with the jumper then if you still have that problem unplug everything EXCEPT the front panel switches and try again. If your still having that issue remove any PCI cards and try again. If you still have a problem try changing the memory. If all else fails try a new powersupply and processor. If none of this works you have a faulty board. Also if you have more than one memory slot and one stick of ram try moving it to a different slot, if it works then that slot you took it out of is possibly bad, but try to reinsert it and see what happens. If the problem reappears its the slot if you put it back in the 2nd slot. Let us know :-)
SOURCE:
Memory problem
When you install your RAM you should make sure it is the same spec as that you removed. I would suggest that you use 2 512 mb sticks as it will be faster than a single 1gb stick. Make sure you buy DDR 400 RAM You need to look for PC3200 RAM.
Apr 10, 2013 | Computers & Internet
I need lan driver for ga-8pe800
Go to Google search and download the driver ga-8pe800 you will get it on the net!!!
Oct 24, 2010 | Gigabyte GA-8PE800 PRO Motherboard
What RAM to use. I would like to use 1600mhz RAM but am not sure what would be the best to use. I am installing 12gb of ram. I will install 6gb now and another 6gb later.
Memory  6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system memory (Note 1)
 Dual/3 channel memory architecture
 Support for DDR3 2100/1333/1066/800 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
and
Memory support list Date Subject 2005/05/12 Recommended memory module list for GA-8I915P Duo Pro ...More 2005/03/01 Recommended memory module list for GA-K8VT800 (Rev 2.0) ...More 2005/02/21 Recommended memory module list for GA-K8NF-9 ...More 2004/12/13 Recommended memory module list for 8I845GE-RZ/C ...More 2004/10/15 Recommended memory module list for GA-8TRX330-L ...More 2004/09/02 Recommended memory module list for GA-8TRS350MT ...More 2004/03/22 DDR400 support list for FSB800 CPU support - GA-8IE2004P \ 8IE2004P-L ...More 2003/12/23 PC3200(DDR400) Recommended module list for GA-8TRS300M ...More 2003/11/28 DDR400 support list for FSB800 CPU support - GA-8PE800 \ 8PE800-L ...More 2003/10/16 Recommended DDR400 (PC3200), DDR434 and DDR466 memory modules for GA-SINXP1394 ...More 2003/10/02 Recommended DDR200/266/333/400/466 Memory support list for GA-K8NNXP ...More 2003/07/23 Recommended DDR333(PC2700) memory modules for GA-8S650GXM-P (-C) ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SQ800 Ultra and 8SQ800 ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SG800 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-8SG667 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-7VAXP Ultra, GA-7VAXP, GA-7VAX, and GA-7VA ...More
Dec 27, 2009 | Gigabyte GA-EX58-UD5 Motherboard
Hi Mike re: GA-8PE800 M./B. what does the BGA
Depending on what you're doing, it actually has a number of different meanings for different fields. Here's a list of Acronyms for it.
BGA Acronym list.
Oct 17, 2009 | Microsoft Windows XP Professional
Please help me I forgot setup password of my computer that main board is 8PE800 PRO-R and bios is 845PE thank you
look for the 3pins near the CMOS battery, change it in position for about a minute, then put it back restart your computer password has now reset
Oct 08, 2009 | Gigabyte 845pe (GA-8PE800PRO-R)...
GA-8PE800 MOTHERBOARD DRIVER
Hi, I'm listing a link below to the GIGABYTE site for your motherboard. Download and install the drivers for your operating system there. If this helps, please rate this answer. Thanks! Hal
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1619
Jun 11, 2009 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
GA-8pe800 pro and kvr333x64c25 memory problem
the 1g is defective return it and get a replcement
Mar 28, 2009 | Gigabyte GA-8PE800 PRO Motherboard
Iv just been given a gigabyte GA-8PE800 motherboard
Gigabyte actually has a very good website. I pasted a link below to the CPU support list.
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1619
As far as what would be the best to buy I would say the closest to the top that you can afford ignoring the P4-Extreme CPUs.
Dec 09, 2008 | Gigabyte GA-8PE800 PRO Motherboard
Ga-k8ns memory problems
did you go into bios and check set up of ram speed etc
Jul 14, 2008 | Gigabyte GA-K8NS Motherboard
Gigabyte GA-8PE800 PRO Motherboard Logo
255 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
