Question about Jl Audio 1000/1 Car Audio Amplifier
Subs fading out briefly but speakers working fine
2 x 1000/1(2 x 12W7) and 1 x 300/4 (4 x C5 650) Usually happens in the morning when the overnight temp was at -3deg C. Voltage is taken with DMM at 14.3 while vehicle idle. listening to system at roughly 30% nominal as its morning and don't need the crazy bass. for about 10 min the system plays fine and the subs are working great, then all of a sudden the subs start to fade back to almost nothing but the speakers driven by the 300/4 are still operating fine. After a few minutes the base is back on fine. sometimes this will happen 2 - 3 time on the 40min drive to work. I pulled over and when the subs faded out only the Green LED is lit on the 1000/1. the amber/red/blue are all out.
    Novelist:
  • 150 Answers
Holy mackerel you have a ton of power i bet that ****** is loudddddd-sounds like your charging system isnt quite keeping up with the amount of current draw that your amps can pull.Upgrade your alternator and look into a dual battery system using an isolator-that way your alt will charge both batteries but your amps will only pull off the one battery-you can look online into how to set that up its not that hard for someone that has managed to install the gear that you already have- Some folks if not most would encourage you to get some sort of capacitor to store power blahblahblah-BUT a dual battery system has waaaaayyyy more storage capacity than a capacitor does-check out the pro competitors online they arent using capacitors to run their stuff they use banks and banks of batteries to get their power-brother you need more juice
Posted on May 12, 2009
I conected my sub wrong and the unit shut down , I reconected my sub and everything seems to work fine , should I send it in for servicing?
If i'm right, the system powers down as a safety precaution. It prevented itself that it will breakdown. It's your choice but I recon you can just enjoy and listen to your favourite music.
Apr 26, 2014 | Harman Kardon AVR 7000
I lost some settings in the volume menu and sub volume
did you blow a fuse, or did you blow out your speakers.
Jan 30, 2013 | Alpine iDA-X100 Car CD/ MP3 Player
Dell MMS-5650 5.1 speakers not working
sounds like they are picking up interference. make sure they are grounded well.
Aug 19, 2009 | Dell 5650 Computer Speakers
The sound from my speaker fades in and out, but the handset works fine.
Since this problem just started, I would first check to make sure there is nothing stuck inside the mic's port. Also, if you have a fan on in the room, that can also cause your speaker to fade in volume.
I say both of these because if the phone thinks you're saying something, your speaker will fade in volume. Whether you're talking or it's just air noise, the volume will fade.
May 22, 2009 | Vodavi 30-Button XTS Telephone
Audiobahn 1800 watt amp has an error of LO and isn't working righ
you are not getting your amp enough volts try checking your ground or power cable
May 19, 2009 | AudioBahn A18001DQ Car Audio Amplifier
Logic X530
i have the same speakers...just right click on the speaker icon on the lower right hand side of your desktop. then click on playing devices then configuration and see if the speaker is in surround mode.
Apr 07, 2009 | Logitech X-530 Computer Speakers
Sub has died overnight
Change the fuse - located at the 220V input. Use a knife ti release it. Then the system will work again.
Oct 08, 2008 | Creative Labs Gigaworks S750 Computer...
Subwoofer stops working after awhile, but only one
it sounds like u blew them or the voice coils could be messed up here is one way to check take the woofer out of the box and look at the coils it should be ornge and then smell it if it smells like fire it might be going bad thats the reson it is frezzing like that let me no what happens and please rate me
Apr 07, 2008 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
At high volume sound shuts off, subs still work
You most likely have a shorted or damaged speaker, which is causing the internal amp chip to shut down (but does not affect the preamp outputs). A test you can do is to fade to one speaker at a time and turn it up to se if it shuts down. Repeat with each speaker until you find the one that causes the fault. Then replace it.
Dec 08, 2007 | Pioneer DEH-2100 CD Player
Jl Audio 1000/1 Car Audio Amplifier Logo
135 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
