Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
Stihl 021 running poorly
My 021 starts easily. But after about 20-30 seconds running wide open it dies out but stays idelng fine. If I shake the saw it will run great for about 20-30 sec. again.
  • Anonymous Mar 20, 2014
    what cc is this saw
  • 666 Answers
Couple of things I would check first. Place a funnel in a can with a paper napkin covering bottom of funnel. Pour the gas from the saw into the funnel. If there is a lot of trash in there, remove the fuel line from tank. Clean the filter with carb. cleaner. Then clean the tank with carb. cleaner. If you still have problem. Replace the Air inlet tube, (clear tube with screw type device close to carb).
Posted on Apr 16, 2009
My 025 stihl chain saw runs erratic from wide open to stop, no idle
I have found that replacing the carb. with a new one . Usually between 27.00 to 38.00 dollars usually saves a lot of time over installing a kit. problem is usually due to a jet problem or the ethanol in the gas has removed the coating on a plug inside the carb. which requires carb. replacement
Sep 20, 2014 | Stihl Chainsaw Parts 021 023 025 Ms210 230...
What causes 021 stihl saw to cut off?
Your chainsaw is running-lean, take off top cover. You should see the air filter. Under The plastic air filter housing is too nuts, 12mm socket is Wot you need next, you need to check these too nuts are tite, these nuts hold the carby to the Intake, all air that goes into the saw is mixed by the carby with fuel. Your saw is running lean. So if those bolts are tite you'll need to check the gasket between the carby and the block....... There are others possibilities but these too are your most likely.
May 03, 2014 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Makita chainsaw starts and revs then dies
check the fuel filter in the tank is clean it could be blocked
Apr 16, 2014 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Which is more reliable..a stihl 017 or a stihl 021 ? looking to bid both in good runnung shape...thanks
Hi, you cant go wrong their both stihls. The 021 is a more powerful saw and the 017 is lighter, so it all depends on your intended use. Regards Phil.
Jun 26, 2012 | Garden
My stihl 021 runs for 30 seconds then stalls
remove the muffler and run it after finding that it runs fine open the muffler and clean the screen inside (it is made to open to clean it)
Jun 22, 2012 | RTO Spur Sprocket For Stihl 017, 021...
Husqu51 starts once but dies then just turns over
take off the muffler and try it if ok then open it up and clean the carbon from the screen
Apr 02, 2012 | Garden
Stihl 023 trouble starting & running
Hi, Replace with correct sparkplug. You have a bad plug replace it and you're good to go.
Mar 11, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Need to know how to take clutch off stihl chain saw ms250
take the bar cover off, remove the bar and chain. there will be a lock key that u can easily remove with a flat head screwdriver, after u get it off all pices should slide out easily, just rember how to put it back and make sure not to mess up the oiler needle
Aug 05, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Fuel is not getting through to the carb,it runs fo...
hi,
it sounds to me that you may have a leak / or perished fuel pipe in your saw...thus only being able to start then stop...
May 20, 2010 | RTO Spur Sprocket For Stihl 017, 021...
I have a stihl 021 chainsaw that will crank and idle fine however it will not throttle up to full speed ,it will accelerate to about half, then it just like chokes out.
For the 021...on the muffler, there is a spark arresting screen, this is to prevent sparks from coming out of the muffler. It is common for this screen to become clogged with carbon from the engine. You will need to clean/replace this screen in order for it to run correctly.
Feb 28, 2009 | RTO Spur Sprocket For Stihl 017, 021...
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
555 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
