Question about Asko T731 Electric Dryer
Dryer overheats and shuts off- vents have been cleaned and button on back has not reset
My asko t731 dryer seems to be overheating. It shuts off after running about 5 min. Tends to run longer on timed dry. If I dry very small loads it runs fine. Otherwise it shuts off
  • 234 Answers
Common problem.
You probably need to clean
your dryer vent. Dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint. You can check the air-flow by going outside where the vents terminate. What's probably happening is on sensor dry, there's a moister sensor that tells the machine to shut off when there's no moister. The hot is is being pushed back into the dryer and confusing the sensor. That's why it's working on timer dryer because that option bypasses the moisture sensor.
I'm pretty sure that's it. Good luck.
Posted on Aug 19, 2009
3 Suggested Answers
  • 958 Answers
SOURCE: ASKO T731 Dryer
you will need a current meter to help me trouble shoot your unit. it is heating but not enough.
we will monitor how long the heater works and how long it is off.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
SOURCE: ASKO T731 Dryer - Air is not warming up.
same thing has happened to me...please help
Posted on Sep 04, 2010
ASKO T731 Dryer
tnx 4 using fixya,
drcool
Oct 14, 2008 | Asko T731 Electric Dryer
Overheating
What is this an asko? It means your vent is clogged or improperly connected. If its an asko, one of the vent covers may have popped off because those have 2.
Jan 24, 2012 | Dryers
My Asko T731 dryer frequently does not have enough starting torque to start rotating the drum. Rotating the drum/shifting the load will allow motor to start. This can occur with a light load or no load. I...
Hi, Yes, you are right about the motor/cap. replacing that can be a bugger but you can do it just dive in a go to town... There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 18, 2010 | Asko T731 Electric Dryer
Too many rpms, how do i slow my dryer down? t731
Welcome to FixYa.
The first thing which comes to mind is this, have you brought this machine into north america from overseas ?
I ask because this is a problem which can manifest from the motor operating on 60hz cycle but designed for a 50hz cycle.
The drum will actually spins too fast hence the items don`t tumble but rather stay pushed to the perimeter of the drum...thus not drying.
If you open the door and run the dryer, the drum on an Asko T731 dryer should rotate at 52rpm. I use a piece of tape on the drum to keep count.
Let me know what you find and we`ll go from there.
Regards,
Macmarkus :)
Sep 16, 2010 | Asko T731 Electric Dryer
My asko dryer stopped drying; the power light stayed on
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 21, 2010 | Asko T731 Electric Dryer
I have the T731 butterflying dryer. It appears to be locked in the 15 hour time delay. How can I get this to start drying now without the delay?
I believe you have to press down on the start button and hold it till the time it's set at appears. Then you can change the time. If that does not work, then unplug for a minute then plug back in. -Tom
Aug 20, 2010 | Asko T731 Electric Dryer
Dec 05, 2009 | Asko T731 Electric Dryer
Asko T731 sensor suuts off the dryer prematurely
you need chek are clean folow:
1-line chute assembly.
2-housing blower.
3- pipe duct .
Oct 05, 2009 | Asko T731 Electric Dryer
Asko T731 Electric Dryer Logo
550 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
