Question about Garden
Their seems to be no spark at the plug - Garden
  • kenmauer May 11, 2010
    Riding lawn mower or push mower?
  • 351 Answers
Remove the plug, put the lead back on the plug and earth the plug to the body of the mower, get someone to pull the starter card and see if there is a spark across the contacts, if not replace the plug as it may be dead
Posted on May 11, 2009
What spark plug is used in an unidentified trimmer/edger?
Ryobi 4-Cycle Spark Plug-AC00164A - The Home Depot
www.homedepot.com/p/...4...Spark-Plug.../203222932
The Home Depot
Rating: 4.3 - ‎3 reviews - ‎$4.97
6 days ago - Keep your engine running smoothly with the Ryobi 4-Cycle Spark Plug forTrimmers. ... Use the replacement spark plug with any of Ryobi 4-Cycle engines. ... Replaces champion RY4C and torch CMR7A.
2-Cycle OEM Spark Plug (RDJ8J) - Sears Outlet
www.searsoutlet.com/2-Cycle...Spark-Plug.../product_details.jsp?pid...
Shop for a 2-Cycle OEM Spark Plug (RDJ8J) (49M0311P953) at Sears Outlet today! We offer low prices and great service.
Nov 28, 2015 | Garden
My 2003 Chrysler Voyager, 3.3L, SFI, runs very rough and at times it almost dies out while driving. The engine seems to choke up at times. I just replaced 6 old spark plugs with 6 new spark plugs, Bosch...
Chrysler Voyager seem function well on Champion spark plugs. I had the same issue and only after buying Genuine Champion Plugs, the car resonded with power
Sep 21, 2011 | 2003 Chrysler Voyager
2000 cavalier is making a flapping noise after changing the spark plugs, the noise seems to go away at faster speeds but comes back when stopped or slowing down. it seems to be coming from the engine.
Sounds like the way you tighten those spark plugs!
Check those spark plugs if they have oil deposit on side, it means there is combustion leak.
Tighten those spark plugs again.
Hope tat helps you out!
Jun 23, 2011 | 2000 Chevrolet Cavalier
1980 CB900: Friend dropped his bike off for me to troubleshoot. Seems to only fire on one cylinder, #1. The others do not. Any ideas on where to start? I have checked the connectors at the front end as...
You have two coils with two wires each. If one plug wire is firing on a coil the other wire is also firing. Start by replacing your spark plug caps and your spark plugs . NGK makes plug caps for around $5 each. Spark plug caps unscrew off the end of the wire and should measure 5000 OHMs on a voltmeter. If they read higher or lower replace them. With any luck all spark plugs will now spark.
Sep 22, 2010 | Honda CB 750 Motorcycles
Wont start up. seems electrical 1975 Yamaha dt 400 What should I check?
check for spark at the spark plug.. if no spark at the plug check the coil for spark where the plug wire plugs into the coil. that bike probably has points. check the points gap.
Dec 12, 2009 | 1974 Yamaha DT 360
Car seems to be only running on 3 cyclinders, when the turbo kicks in it seems to smooth out?
pull spark plugs and check how they are burning. See if one looks worse. Check to be sure you have spark from all 4 spark plug wires. May need a plug, new wires or distributor cap.
Jul 01, 2009 | 1991 Mercury Capri
Loss of power and seems to be trumping !
inspect boot of spark plug wires and for corrosion at coil where sp.plugs wires connect,good chance wires are due.
Mar 14, 2009 | 1998 Hyundai Elantra
Spark plug replacement
Just pull hard, it does seem pretty tough, but you won't damage anything as long as its a hard consistent pull. Don't TUG, but pull increasing the pressure until it comes out. It needs to be a snug fit in there to keep debris/moisture etc from getting to your spark plug!
Jun 27, 2008 | 2004 Dodge Neon
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
