Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Gearbox worn, terrible noise, needs to be repaired
The gearbox in my 600 series mixer is worn out. Contacting KitchenAid was frustrating, way too much money. The mixer is only 3 years old and should not make any of the noise it does. It has been handled properly.
(not even bread dough).
I am looking for a repair shop that can repair the gears. My location is Marietta, GA, 30075.
Any help is appreciated.
  • Rick Belanger
    Rick Belanger May 11, 2010
    Try your local Yellow Pages.
  • 135 Answers
Hi. Try your local Yellow Pages. ricardok45
Posted on Apr 19, 2009
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Oil leaks out when tip up .around
KitchenAid uses a vegetable based grease inside of their mixers, it is a food safe grease. Because of this if you do not use your mixer often and over time the grease inside the mixer can begin to break down, and an oil will leak from the mixer.
What you will need to do is take the mixer apart, clean out the old grease and replace it with new KitchenAid grease, it is also recommended that you replace the gearbox gasket.
We are one of KitchenAid's largest service centers in the US, everything we sell is Genuine KitchenAid replacement parts.
Here is a link to the grease on our website: http://www.mendingshed.com/kagrease.html
And a link to the gearbox gasket: http://www.mendingshed.com/mixergasket.html
Also to aid you in the repair here is a link to the KitchenAid service manual for your mixer. this will show you how to take the mixer apart, replace the grease, and reassemble the mixer. http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Mar 30, 2013 | KitchenAid K45SS Classic Stand Mixer
I dont know what else to add other then the oil came out of the mixer when i moved and i do not know what type of oil to put back in it and where do i put it in to the mixer on my kitchen aid mixer
Wipe the oil off and carry on. Over time the gearbox grease breaks down and oil separates from the grease solids. Eventually the gearbox will need to be repacked with new grease. Don't worry about a drip or two in a cake, it's food grade grease so harmless.
Dec 09, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
Stand mixer leaking oil
Your gearbox grease is breaking down, time to repack it with some new stuff.
Nov 30, 2012 | KitchenAid KSM150PS Artisan Series Stand...
Mixer is turning but any pressure on the planetary and it stops
Most likely you will need a new fuse gear, it is inside the gearbox.
Nov 25, 2012 | KitchenAid KSM150PS Artisan Series Stand...
OIL IS LEAKING OUT OF THE HEAD INTO FOOD BOWL. KITCHENAID SAID OK, FOOD GRADE OIL! I DON'T LIKE BLACK OILY CAKE OR COOKIES? CAN YOU HELP US TO FIX OURSELVES.
Kitchenaid says to run the machine on 'high' long enough to heat the gearbox well and then turn the machine upside down and let it cool.
What happens is when you don't use your mixer a lot the grease in the gearbox will separate into oil and thicker grease. Warming it and turning it upside down is supposed to mix all the grease together again and allow it to flow to the top of the gearbox.
Give it a try, check back if you get no satisfaction and we'll get you started on changing your grease.
lp
Jan 01, 2011 | KitchenAid KSM103 Professional 5 Series...
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
Nov 02, 2010 | KitchenAid K45SS Classic Stand Mixer
Utencils touch the bottem of bowl
it sounds like the planetary has gotten loose and dropped down. Check out this parts list so you can see how it is put together.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
Try pushing up on the shaft which holds the mixing attachments. It should not move more than 1/32 inch - if it does then something inside the gearhead is worn and you will have to take it apart. If the whole planetary moves up and down then something deeper in the gearbox is worn.
To take it apart lay it on its side and carefully pry the chrome ring off. Now drive out the pin that goes thru the planetary and the shaft. Now pull the whole planetary off its shaft. Remove the six screws underneath plus the other screws you can see from the bottom of the gearbox - there are 4 more. Now carefully pull the top half of the gearbox from the bottom half, which will expose the gears. Examine for worn parts and replace the necessary ones.
Apr 12, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
I have oil leaking from the beater shaft. a lot
TRY REPLACING GREASE IN GEARBOX AND MAKE SURE YOUR FELT COVER IS IN PLACE (AND CLEAN) THAT SITS UNDER GEARBOX.
**** KENWOODCHEFUSEDMIXERSANDSPARES
Jan 05, 2010 | KitchenAid KSM150PS Artisan Series Stand...
There is a banging / clicking noise when moter is
With the machine unplugged, remove those two black screws on the side and pull out the motor brushes. Make sure the metal blocks on the ends of the springs are in good shape. These wear out and the screws are there to easily replace them. You can order new ones cheap from kitchenaid. If it's not those brushes then the problem could be in the gearbox and you can't fix it. Are you sure it's not a bent wire whip or mixing paddle banging against an improperly seated bowl?
Sep 19, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
586 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
