Question about Dishwashers
The "water inlet fault" message is showing up on my Asko 3530 dishwasher. We have taken off the inlet hose and it is clear. What else should we try?
  • dakitty Apr 15, 2009
    I will try the suggestions. Thanks
  • 19,396 Answers
That is a faulty or clogged inlet valve, or a water level floater stuck down inside the machine.
First ensure that water is flowing regularly through the inlet hose. If you find nothing in there, then the thing to do is accessing to the inlet valve and testing it. Also check the water level floater is not stuck.
The inlet valve is tested by reading voltages, reading continuity, and physically checking if it is closed.
If it turns out that inlet valve is fine, water level is fine, there is no blockage and water supply is fine. Then only in that case test and eventually replace timer board.
Posted on Apr 15, 2009
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
Jun 08, 2011 | Asko D1976 Built-in Dishwasher
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
My asko dishwasher flashing F2. Can't stop it! What do I do! Thanks, Elva
Hi
Hope it helps...
Feb 16, 2011 | Dishwashers
We have an asko 3530 dishwasher that is 4 to 5 years old now and when we run any wash cycle some time during the cycle we get an error that that says water inlet fault. Is there a filter or something we...
Some do have a screen but most don't. It could be possible that your feed line may be kinked? There is also the valve at the water inlet that could possibly going bad as well. Hope this helps.
Jun 07, 2017 | Asko Dishwashers
Attempting to install asko d1706 dishwasher. Bought used, had no hoses with it. when trying to connect water inlet hose, unable to connect without leaking. Finally got a connection on there that has it...
yes there are actual dishwasher supply hoses you can purchase at most hardware stores.... if you do have the correct hose may try to put some teflon tape on connection so that leak stops....
good luck to you
Jan 20, 2011 | Asko Dishwashers
Dishwasher will not drain. F2 shows up on panel
Hi
Hope it helps...
Daniel
Aug 20, 2010 | Asko Dishwashers
Overfilling fault
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
May 13, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Our Asko D3250 dishwasher is brand new, and it fills up and drains and fills again and then the water inlet fault flashes. It doesn't go past this point.
this sounds like a improper install ! ck to see if the drain hose outlet is lower than bottm of tank. it should drain to the disposal . and have a drain loop under sink .. the dw prosser is sensing that the drain is longer in time so it flasher inlet fault . . elevate the drain and try again ..if it drains to a lower use a stand pipe or a siphon brake . in the install .. mm
Dec 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
MY DISHWASHER DON'T WORK THE FAULT CODE IS f. wHAT
The F2 problem in Asko dishwasher is due to the high water level condition.The reason is bad water pump or a defective water inlet valve. you should try replacing this and your problem will be fixed.
Sep 10, 2009 | Asko Dishwashers
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
