Question about Brother Multi-Function Center MFC-3360c All-In-One InkJet Printer
Have a brother mfc3360c and had to install windows xp
I can print but i can not scan or fax and the status monitor does not seem to be connected with the pc... i switched the port and it does fax manually. but not through the control. scanning does not work at all it gives me this message scanning failed and cc3-205-03031f02
You do not have the right driver downloaded. I actually just had that same problem. I could print but not scan through the CC3 panel. Follow that link and download the correct driver. http://www.brother-usa.com/downloads/
Posted on May 07, 2010
"Cannot be contacted over this network" after trouble shooting.
USB or Bluetooth? Put network settings in copier that match your inernet settings in Windows.
Nov 15, 2013 | Brother MFC-8480DN MFC8480DN...
My brother printer has an error unable to clean 50
XXXXX XXXXX look on the printer, do you have these keys:
Menu/Set, Black Start, or Function?
Brother Printer Support
Sep 28, 2012 | Brother LC51BK Print cartridge, Inkjet...
How do I get my Brother MFC-6490CW to connect with wireless connection. I can print a test page to it wireless but windows fax and scan does not find it
Ensure you have properly installed the communication between the printer and the hub and only then install the relevant software to windows. It appears that something has not properly being installed.
Jul 28, 2011 | Brother MFC 6490CW InkJet Printer
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
Brother MFC-210 fax issue
Install fax software . You can do this with the following procedure:
go to control panel, go to add and remove softwares and then in install windows components install fax .It will ask u for a windows cd
Dec 08, 2008 | Brother MFC-210 All-In-1 Print/...
I cant scan
You have to connect the mfc directly to a USB port of your computer. DO NOT use a hub.
The mfc uses the XP buil-in scan driver.
Did you install the whole mfl-pro suite? Use paperport to do scanning from your pc.
Jan 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
Epson CX5800F printer Netgear PS121 Print Server difficulties
Here is a workaround:
http://newsgroups.derkeiler.com/Archive/Comp/comp.periphs.printers/2007-08/msg00456.html
Another thing to try if it STILL doesn't work is
Printer&Faxes>>Properties>>Advanced>>"Print Directly to Printer"
Just remember to restart after you try both of these. The Status Monitor in it's current for (at least for me) simply sucks.
Dec 04, 2007 | Epson Stylus CX5800F All-In-One InkJet...
Scanner
Download and install full software and driver package for your machine from brothers web site, it sounds like you have installed the print drivers but not the scanning software.
Oct 27, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother Multi-Function Center  MFC-3360c All-In-One InkJet Printer Logo
639 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
