Question about Aquascape Designs Aquascape - AquaForce Solids Handling Pump - 1500 GPH Submersible Pump
I have an Aquascape SFA3000 pond pump. The flow rate has reduced to about 1/2 of what it was. The impeller spins when it is plugged in, so it appears that it is not jammed. The problem is that I need the full flow to make it to the waterfall and work properly.
5 Suggested Answers
  • 634 Answers
SOURCE: Several years ago I jumped right into building a
NEED filter box to keep pond cleaner and pump healthier, the gunk will just build and cause pump loss and aggravation.
Posted on Jul 17, 2009
SOURCE: Pump started making whining noise - I took it out
Called my installer who recommended replacing it with the Aquasurge model. Keeping my fingers crossed this one lasts.
Posted on Dec 20, 2009
  • 5 Answers
SOURCE: rebuild kit for the Aquascape SFA3000 Pump???
I have had the same problem everyone else has had with these pumps. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Posted on Mar 09, 2010
The trick to a koi pond is filtration and the pump is part of it. What you want is a pump that will move the water about once an hour. So a 6-700 gal / hr pump would be minimum. But with a 3 ft waterfall you may need a 1500 to 3000 gal/hr pump. The box will tell you the gal/hr at a 3' head.
Now how do you keep the pump inlet from clogging? How about we only pump clean water. You do that with a gravity flow settling chamber. You need a outlet in your pond going to another big chamber where the fish muck can settle to the bottom. You can put filter material across the settling chamber. Remember the wider and slower the water the better. The solids will settle by gravity requiring less filters or filter cleaning. So then at the top of this chamber you now have clean water from there you can pump. Also with the fish waste settled you won't be grinding it up into a pump making a fine slurry that is always perfect for a summer long pea soup algae bloom.
Now at this point you should spray the water out causing the most oxygenation you can. This is where the beneficial bacteria can turn fish ammonia to nitrates and then to the much less toxic nitrates that floating plants and others love to feed on creating a balanced pond. These bacteria are aerobic and want maximum oxygen in the water. So design the bio filter with a media that is light and has maximum surface area. Keep this area out of direct sun and dont let the water blast the bacteria off the media. From there let the water fall back into the pond adding even more oxygen. My 500 gal pond uses these ideas and I only clean the pump inlet and the prefilter 1 or 2 times a year and the biofilter has never needed cleaning. There are many ways to keep a koi pond but the closer you stick to these rules the healthier your pond and fish will be and the less maintenance they will need.
Posted on Nov 19, 2014
Pump is making a grinding sound. it has been pulled and is debris free. the pump is approx.5-6 years old
Check the impeller shaft for cracks and rough patches. harlok_6.jpg If the impeller shaft is still smooth and in one piece the main motor bearing is damaged or worn out. A main bearing is not replaceable as accessing it would compromise the motor housing.
Apr 20, 2011 | Aquascape Designs Nursery Pro Ultra Pump
My Aquascape 4500 pump immediately trips the GFI when I plug it into an outlet. This happens both when it is submerged and out of the water. The impeller is not obstructed.
The seal has failed allowing water into the sealed motor unit and it is now shorted to ground...in other words the unit is shot and needs to be replaced.
John
Apr 07, 2011 | RTO AquaScape 4500 GPH Pump
Impeller shaft broke at impeller. moytor started to make loud noise . removed end of pump to find impeller at bottom of housing.
i have the wsame problem. A new pump will run me 550 I dont think I could replace the impeller shaft
Oct 17, 2010 | RTO AquaScape 4500 GPH Pump
Shuts off intermittantly, impeller moves freely
Does it come back on after resting/cooling down. If does peobably kick out on heat overload and is resetting itself. If impeller is free spinning with NO roughness or side play in bearing probably too much head pressure,pumping too far or too small pipe wich will cause excessive pressure making pump work to hard
Apr 10, 2010 | RTO AquaScape 4500 GPH Pump
Aquascape 4500 pump trips breaker when plugged in
water getting into pump.Thats what is triping it.
Jul 31, 2009 | RTO AquaScape 4500 GPH Pump
Rebuild kit for the Aquascape SFA3000 Pump???
Jun 18, 2009 | Ultra Max Aquascape AquaBasin, Pond or...
Aquascape Designs Aquascape - AquaForce Solids Handling Pump - 1500 GPH Submersible Pump Logo
268 people viewed this question
Top Aquascape Designs Garden Experts
Dennis Key
Dennis Key
john h
Are you an Aquascape Designs Garden Expert? Answer questions, earn points and help others
