Question about Mitsubishi ES100U Multimedia Projector
Need to reset lamp timer
I work at a movie theater and our preshow is projected with the mitsubishi es100u but a few of ours stopped working. I need any advice you can give me and i also need to know how to reset the lamp timer wich is what the guy who installed them seems to think is the problem.
  • 4,234 Answers
The lamp timer expiring would not shutdown the unit typically. Purchase a replacement lamp and included will be the instructions to both replace the lamp and reset the timer.
Dan
Posted on Apr 16, 2009
  • ABRsvcs Apr 16, 2009
    I must correct myself. It turns out that these particular projectors WILL shutdown if the lamp timer exceeds a certain number. Replace the lamps and reset the counters by holding down the left and right arrow buttons as well as the power button for at least 3 seconds.
    Dan
Our 72 in Mitsubishi tv keeps shutting off after a bulb replacement
ensure the lamp timer is reset otherwise next the lamp will completely be damaged get to the net and get the lamp reset procedure for that model and ensure its done this will solve tthe problem
Jul 17, 2013 | Televison & Video
How to reset lamp timer on mitsubishi wd-65734
This model there is no reset for lamp timer.
Nov 14, 2009 | Mitsubishi WD-65733 65" HDTV
WD-52631 Audio works, but no picture
Probably a bad lamp. This is the first thing I would try....especially if the lamp has not been re[placed in awhile.
Oct 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Lamp light just blinks yellow after lamp replacement, tv does not turn on
I will recommend to take the lamp out and slide in again, it might be that your TV havent detect that there is a new lamp. By doing this you will reset the lamp timer. If dont work search in your manual how to reset the lamp timer.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Projector suddenly shut down
you need to reset the lamp timer. turn it on, and press and hold the left arrow, right arrow, and power button until it resets.
Dec 17, 2008 | Mitsubishi ES100U Multimedia Projector
We recently replaced the bulb in my projector, but it continued to flash "replace bulb". Today, it was running fine then suddenly shut down. The power light is on, but the projector is not on.
IF you did not reset the lamp counter, the unit will shutdown. To reset, press the left and right arrows along with the power button for at least 3 seconds. That will reset the timer. Update this if that does not resolve the problem.
Dan
Lamp replacement
The file is too large to post here but if you post your email address, I can send you the step by step instructions to replace the lamp and reset the lamp hour counter.
Mar 01, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Problems with Mitsubishi WD-52525
When you replace these laps on these TV's they have an internal clock to countdown the lamp usage. After installing the new lamp the TV asked you if you replaced the lamp and you should answer yes. If not its going to ask again. First thing is go through the motion of replacing the lamp take the lamp out etc. then place it back in the set and turn it back on. Follow the on screen instructions and that should reset the lamp timer.
Jan 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ES100U Multimedia Projector Logo
691 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
