Question about Philips 32PT6441/37 32" TV
No video signal
Some of the channels on TV were missing so I run Auto Program to get them. Now, when I switch to SVHS to watch DVD I get audio only, and no video. Is there anything I should do to enable it?
  • Anonymous Apr 16, 2009
    no signal
    Problem Solver:
  • 9 Answers
You need To cut The Wire and Put Them Again In ur DVD or Num
Posted on Apr 15, 2009
What do you mean cut the wire ? Im having a similar problem I cant put my TV in video mode my AV button to the original remote is not working.
Posted on May 29, 2012
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
Looking for user manual for philips magnavox tv. 9P6044 C104, 3911Q1716. Trying to find out how to hook up my VCR to this tv. It has s viedo, video, L audio & R audio holes on front side of tv. I want...
Barb..be sure you run a TV signal through the VCR first. And then a coaxial from the VCR to the TV. This is the easiest solution for now. And set the vcr to tv/video {channel your movie is on}hit record and hit tv/video and watch your tv for another movie!
Feb 06, 2010 | Philips 9P6044C 60" Rear Projection...
How do i upload video to pc?
You can do this by connecting up your camcorder to to your video IN on your PC If you don't have one, then you must install one, USB to TV/Video & associated software, and using the Composite or SVHS input. Connect the video OUT from your camcorder to the USB, PC Video/Audio IN & Audio too, & record by pressing "Play" on tape, and "Record" on the Program on the PC. Then you can watch, Play or burn to CD/DVD.
Feb 02, 2010 | Video Cameras
We have been trying to set the channels in our old picture tube tv. it scans through the channels and once complete, you can only watch the last channel found and once you go to change channels, it...
Be sure your tv is programing with a correct signal. Air or cable channels, and that you do have a line going into the RF connector [antenna signal]. If you have a satellite or cable box your tv will only tune to channel 3. Also, if you are logged into a dvd player or vcr...you will only have one channel memory. Remove any of the external players [games,dvd,vcr etc.] And retune with auto program!
Jan 09, 2010 | Televison & Video
VCR with intermittant audio and video problems
you have to connect VCR output cable to your TV input, thats all, it will be in series, if u want to record any program then on your TV and on record switch of your VCR.
Dec 30, 2008 | Sony SLV-N55 VHS VCR
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Dvd burner
Can you try just running a/v cable from your tv output to the inputs on the ilo, then whatever you watch on your tv you can record on your dvd burner. My new SDTV doesnt have audio out except Coax so this won't work for me on that tv. Why doesnt the newer tv's have audio AND video outputs???
Oct 30, 2007 | iLO DVD Recorder DVDR05
Digital Audio moved from TV/SAT to DVD/LD
Using the remote control, push the left arrow until display shows Coax1 (or 2, depending on your setup), then push the up arrow to set it to TV/SAT.
Conversely, depending on your setup, you can push the left arrow to display Comp1 (or2) then push the up arrow to set the correct video setting-- DVD/LD I assume.
Apr 09, 2007 | Pioneer VSX-D514 Receiver
Philips 32PT6441/37 32" TV Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
