Question about Brother MFC 210C All-In-One InkJet Printer
Lcd reads machine error 41 ,it started with cannot initiat i pressed menu/set and *2864 within 2 secs then error 41 came up
  • 4,041 Answers
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Posted on Mar 01, 2010
How do i unlock brother mfc-7420 laser printer
Enter maintenance mode - Press menu * 2864 9 within 2 sec.) press 91 to reset all settings to factory fault . then press 99 to exit .
Nov 11, 2014 | Brother MFC-7420 Printer
On my Brother MFC410CN Printer Message reads Unable to clean I have followed TroubleShooting instrctions and it still appears
MFC620CN/425CN/420CN/410CN/215C/210C and FAX2440C
Press the Menu/Set, Black Start, Menu/Set, and Black Start keys in this order.TIP: For the FAX models equipped with numerical keypads, you may press the Menu/Set, Black Start, and 0 keys instead in the same way as conventional models.Then "MAINTENANCE 10" appears on the LCD. Press 82 using the numerical keys/arrows.
Then press the Menu/Set key.
Error code will display indicating source of error if it is 41 thats print head error,
replace machine.
press stop to exit if needed.
(http://www.fixya.com/support/t250171-brother_mfc_215c_unable_clean)
Oct 06, 2008 | Televison & Video
Error 76
try this- press the "menu/set" button, then " *2864 " . the *2864 you have to enter within a 2 second window, so you may have to try this more than once. when you hear a long beep, you got it. press "91". you should see "parameter init" on screen. wait for that message to disappear. unplug machine at this point, wait 5 seconds and plug back in. if it comes up with that error again, then you truly have a problem with your fusing unit and will have to have repaired. sometimes though, this error can be caused just by a power outage or fluctuation. if thats the case it should come back up to normal after you successfully do this procedure.
good luck
razors
Sep 21, 2011 | Brother IntelliFAX 4750 Plain Paper Laser...
I need to restore our fax (Brother 4100e )back to the original settings to remove all the phone/fax numbers. Can you help?
press the "menu/set", and then "*2864". you have to press these within 2 seconds. machine should beep and say "maintenance" when you've entered correctly. then press "01". panel should come up and say "parameter init". when that message clears, press "99". that should take you back to normal display.
good luck,
razors
Aug 11, 2011 | Office Equipment & Supplies
Brother 165c clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide. clean unable 46
Error 46 on Brother printers The printer must be reset:
  • Press menu then*2864 within 2 seconds and press 80.
  • Keep pressing black/mono start button until screen displays 'purge count'.
  • Press 2783 to reset purge count.
  • Press stop/exit key
  • Press 99
  • The printer should return to normal
OR Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 12, 2011 | Brother DCP 165C Compact Color Inkjet...
My MFC-3240C Brother Printer reads: Unable to Clean. What can I do
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
May 10, 2010 | Brother MFC-3240C All-In-One InkJet...
Getting error message CLEAN UNABLE 46
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
Mar 07, 2010 | Brother DCP-135C Flatbed Digital MFC...
How do you reset a Brother MFC-7840W printer to factory default settings?
Menu * 2864 (within 2 sec.), 0,1, when 'maintenance' appears, press 0,9 to exit.
Dec 08, 2009 | Brother MFC 7840W Printer
The power went out at the office. when the power was restored my brother intellifax 5750e will not work. there is an error 77 message displaying on it's panel.
you can try this. press "menu/set" " *2864 " within 2 secs. then press "01" and wait for a few seconds until "para init" goes away. then press "99" and when you see "please wait" unplug machine. wait for 15 secs. and plug back in and see if it comes up. if not, then you have a hard error and must have serviced.
good luck,
razors
Mar 03, 2009 | Brother IntelliFAX 5750e Laser Fax
Factory Default Settings
Press Menu * 2864 (within 2 seconds) [MAINTENANCE MODE] press 01 (INITIALIZE)
Jun 05, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC 210C All-In-One InkJet Printer Logo
198 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
