Question about Panasonic CQ-VD6503U Car DVD Player
Security Code enabled
I dont know how but my head unit went into security mode and the securiy light now flashes red. I can not get the unit to turn on nor can i get it to display a request for any sort of code. Could this be a fuse or is there something else going on here? Your help is greatly appreciated. Thanks.
  • Anonymous Feb 09, 2008
    yes i have the same problem cant get my unit to come on
  • 20 Answers
Try thr reset button on the front lower left hand corner
Posted on Nov 14, 2007
2 Suggested Answers
SOURCE:
  • 67 Answers
SOURCE: Security code light blinking nodisplay on lcd
If you have not already tried resetting unit. Bottom left of unit you should see a small round reset button. Press this small Reset button with a Pen or other pointy object. If this does not work refer to trouble shooting section of Owners manual to see if any of that info may help.
http://service.us.panasonic.com/OPERMANPDF/CQVD6503U-MULTI.PDF
If you need service manual I may be able to help [email protected]
Posted on Jan 18, 2008
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Dec 26, 2015 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
Harley fob 05 fat boy
2005 Softail ARMING/DISARMING SECURITY SYSTEM (TSSM) 3.7
GENERAL
The security system can be armed automatically by the TSSM when the bike is shut down or manually by the use of the fob and it can be turned off automatically by having the fob within range when the ignition is turned on or by entering the PIN or personal code.
The security system lamp in the speedometer head confirms the status of the system as armed or disarmed.
The range within which the fob will work is dependent on the environmental and geographic conditions so the fob should be held at about waist level and horizontal to the tssm and pointed at the front of the bike with the fob button held down until both of the turn signals flash twice which indicates that the TSSM has responded to the fob and the security system has been activated. To disarm the system the fob should also be held at about waist level and horizontal to the TSSM and pointed at the front of the bike and the fob button rapidly pressed two times within 1.5 seconds after which if the TSSM has responded and turned off the security system the signal lights will flash one time.
The fob is synchronized to the particular TSSM and the fob button should not be pressed very often when it is away from the bike because this might cause it to become de-synchronized to the particular TSSM which would require that the fob button be pressed and held within range of the TSSM for 10 to 15 seconds or until it is re-synchronized and the signal lights flash two times in response.
The personal code (PIN) consists of five numbers or digits each of which can be any number from 1 to 9 that are individually entered into the security system by using the left and right turn signal switches. This number can be used to disarm the security system without the fob. If an error is made while entering the PIN the TSSM will activate the alarm for 30 seconds after the fifth digit is entered and the security lamp will flash every second for ten minutes and there cannot be any further attempts to enter the code during this ten minute period.
The way to enter a personal code is to set the RUN/OFF switch to OFF, turn the IGNITION key to ACC, hold both turn switches in until the security lamp blinks at a fast rate to confirm that the security system is ready for personal code entry, THEN enter the first PIN digit (number) by pressing the left turn switch button a number of times equal to the value of the first digit of the PIN, i.e. for 1 press once for 2 press twice etc., then press the right turn signal switch button 1 time to enter the first number, THEN press the left turn signal switch button the number of times that is equal to the second number of the PIN, followed by pressing the right turn signal switch button 1 time to enter the second number, then press the left signal light switch button the number of times equal to the third number of the PIN followed by pressing the right signal light switch button one time to enter the third number of the PIN, THEN press the button of the left turn signal light switch a number of times equal to the number of the fourth PIN number followed by pressing the right signal light switch button once to enter the fourth PIN number, THEN press the left signal light switch button the number of ties that is equal to the fifth number of the PIN followed by pressing the right turn signal switch button one time to enter this final number of the PIN at which point the security lamp in the speedometer head will stop flashing and the signal lights will flash once to confirm that the security system has been disarmed.
If the security lamp light in the speedometer head does not flash the security system is not armed or the bike does not have a security system or the system if installed is in storage mode.If the security system light in the speedometer head flashes every second for ten minutes there has been a failed PIN entry attempt. If the security system light in the speedometer head flashes once every two seconds the security system is armed. If the security system light in the speedometer head flashes 3 times per second the system is in PIN entry mode. If the security system light stays on solidly with the ignition key OFF auto-arming is commencing and there will be a 30 second period before the system is armed. If the security system light in the speedometer head stays on solidly for more than 4 seconds with the ignition switch ON there is a current DTC(s) set.
With a TSM if the four-way flashers flash 6 times shortly after the ignition switch is turned to ON you should check for DTC's that have been set.
A TSSM diagnosis starts with observation of the security system light in the speedometer head at KEY ON which means that the run switch and the ignition switch are both ON without starting the engine. When the ignition key is turned ON, the security lamp will illuminate for approximately four seconds and then turn off. If the security lamp is not illuminated at Key ON or if it fails to turn OFF after the initial four second period, the speedometer may be defective and need to be replaced. If BUS Er is displayed on the odometer, it may take up to twenty seconds for the security lamp to illuminate. The security lamp will also light for eight seconds after the first four second bulb check period if any historic diagnostic trouble codes (DTCs) are present. After the initial 4 second bulb check period of lamp illumination the security lamp will stay on if current DTCs are set. If a historic DTC is present, the security lamp will continue to light for 50 ignition cycles or until the DTC has been manually cleared away. After the lamp turns off after being illuminated for the first four second period, one of three events may occur: 1.The lamp will remains off which indicates there are no current fault conditions or stored historic DTCs being detected by the TSSM. 2. The lamp stays off for four seconds and then comes back on for an eight-second period which indicates that a historic DTC is stored, but no current DTC exists. 3. If the lamp remains on beyond the eight-second period a current DTC exists.
May 20, 2014 | 2005 Harley Davidson FXSTI Softail...
2003 FLSTC heritage alarm system.
FOR 2002 Security System 1 long push on the remote turns it on, 2 quick clicks turn it off.
May 20, 2014 | 2000 Harley Davidson FLSTC Heritage...
I have a 1998 Acura CL 3.0, I do not get any power to the radio except for the security red light
acura cls have a securiy feature that once the battery is disconnected you need a code for the sterio to work. if thats not it pull the head unit out and make sure the power wire is fully clipped in
Nov 03, 2013 | 1998 Acura RL
1996 acura TL wont start.
possible you have to reset antitheft mode ,is there a red light flashing when you turn key to on possion not starting it ? some will reset by putting key in drivers door and turning it open close 3 times look for lights to flash then try to start.
Sep 12, 2012 | 1996 Acura TL Series
I forgot the security code of nokia 8600 how to reset
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 04, 2012 | Nokia 8600 Luna Cellular Phone
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Thanks.
Jan 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
Panasonic CQ-VD6503U Car DVD Player Logo
315 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
