Question about Maytag MAH6700AWW Neptune Front-Load Washer
Front loading maytag washer door won't open. Help!!
Washer cut off after completing cycle and door will not open. I know I can manually open it but how how do I fix problem so it won't happen again?
  • domino14 Jun 17, 2009
    Thanks, you had right answer!!
  • Maytag Master
  • 3,361 Answers
Remove the lower front panel.Reach up inside near the latch. Feel for a ring tab. Pull it down firmly while pulling on the door.
Then open the cabinet and check all the wire connections in the latch circuit. Check the wax motor ohms. The wax motor probably needs replacing.
Posted on Apr 15, 2009
  • 209 Answers
SOURCE: maytag neptune front loading washer
purely based on the vague information you have given, this could sound like the drum bearings and the fact that it has been neglected for so long has resulted in serious damage to your machine, note to all, never continue to use machines making noises, it can only get worse and do mare costly damage, after all the problem could have been a very inexpensive fix problems on this and any other site, to be fixed by messages (without actually seeing the machine) can only be fixed - or advice can only be given based on the details that are given if you say my machine just stopped then you will not get an answer will you? engineers can help sort out lots of problems without seeing the machine if we are given the right DETAILED information, no matter how silly it sounds, so before you shout and complain at others, have a thought about what you are going to write sorry its bad news but i hope i have helped
Posted on Oct 02, 2007
  • 1294 Answers
SOURCE: Maytag Model # MAH4000AWW Neptune
Clean out your filter after ref. to user's manual. Try some WD40 on the door mechanism (on machine), lock & unlock door 5 or 6 times while machine is off.
Posted on May 10, 2008
huuum
  • 750 Answers
SOURCE: Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
Maytag317
  • 1136 Answers
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
Posted on May 30, 2009
GodBlessU
  • 3513 Answers
SOURCE: maytag washer is leaking out of front door, its a
There are a couple of steps to be done to fix the issue. Please follow the steps provided in the bellow mentioned link:
http://www.ehow.com/how_2089565_fix-washing-machine-leaks.html
Thank You
Posted on Sep 12, 2009
The washer door is locked and will not open
Problem with Maytag MHWE450WW front load Maytag washer. The washer door is locked and will not open. I tried several suggestions in the manual, but none work. Please help!!! My email address is
hummingbird54@verizon.net and my name is Antoinette Roy
Oct 10, 2012 | Maytag EPIC MFW9700S Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
    Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
    http://www.servicematters.com/maytag_library/docs/16010061.pdf
    Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
    Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
    See the manual:www.applianceblog.com/manuals/MaytagNeptunenew.pdf
    Joe
    Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
    Maytag MAH21pddww door locked
    hi thanks for the question to unlock the dor manually open the soap door look to the right top inside its a small piece of string pull on it. that should unlock the door thanks the appliance doc
    Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
    WAsher not working
    FL means 'failed to lock' the door didn't lock, so it didn't complete the cycle. Sometimes it's just because the door didn't shut completely or you may have a bad door latch assembly, or worse case, a bad control board. First try unplugging it for 5 minutes, then try starting another load making sure the door is closed completely, if that doesn't help you'll need to open it up to test the door latch.
    Jul 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag neptune won;t rinse
    Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
    Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Front load washer
    LO means bad door lock switch or conrtol board. to get it open unlock manually by pulling plastic cable located in dispenser where soap is put in.
    Oct 29, 2007 | Maytag Neptune MAH5500B Front Load Washer
    Maytag MAH6700AWW Neptune Front-Load Washer Logo
    3,577 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
