Question about Frigidaire Ovens
F1 on Clock
When I turn the Frigidaire oven on after a minute F1 pops up where the clock is and then beeps and it does it every couple of minutes.
  • Frigidaire Master
  • 3,361 Answers
Your ERC is bad(clock).
No repair, must be replaced.
Posted on Apr 15, 2009
Have a Frigidaire FEF353bfwc. Getting error message F1 and start button lights up and beeps constantly. What to do? Can it be fixed? and what would you guess is approximate cost?
Hello there and thank you for choosing fixya
The dreaded F1 error code can be difficult to diagnose but here is the best thing to do
this is from the manufacture of the oven.
F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Aug 05, 2011 | Ovens
OVEN WONT SHUT OFF F1 COMES UP AND IT BEEPS
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock)
Feb 13, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
What could be the problem if F1 code and beeping in GE wall oven/
F1=Touch control pad and or Clock defective.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
Jan 11, 2011 | Ovens
Displaying F1 error
Apr 04, 2010 | GE JGRP17 Gas Single Oven
It displays F1 . Is this a fuse problem and where is the F1 fuse
HELLO THERE
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Feb 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
F1 signal started today can't turn the alarm off.model kenmore 9114832593
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F1 and listen for the beep.
  • If you get the F1 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
  • Let me know if this doesn't point you to a solution. There are a couple of more things to try.
    Feb 01, 2009 | Ovens
    Fault Code F1
    Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
    Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
    Ovens Logo
    83 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
