Question about Viking VGSC306-4B Gas Kitchen Range
Need to replace griddle thermostat
I need to replace the griddle thermostat on my 48" 6 burner viking range with a griddle. Can I access it just by lifting the griddle off of the frame?
My husband and I just had to check out our griddle on our 48 inch Viking rangetop. You remove the grates and the grate holders on either side of the griddle..it just pops out. Then you raise your griddle up about 4" to remove your thermastats., noting the position they are in so when you replace you can put back correctly. After pulling the thermastats out, then you lift the griddle out. Griddle is extremely heavy so be prepared to have close surface to lay it. Hope this helps.
Carole
Posted on May 25, 2009
I have 48 " 6 burner stove natural gas.Stove is
the glass in the ovens should not crack when self clean is used. it could be that there was a minut crack in the glass or a build up of moisture in between to door windows that expanded at the extra heat but this should be brought up with the manufacturer for replacement.
I hope this was useful.
Jan 05, 2011 | Viking 48" 6 Burner, Griddle Professional...
Is there a cleaning manual for my 6 burner/griddle viking range?
I have a product that I use to clean my burners and griddle with, it is made by ECOLAB and is called Greasecutter Plus. It doesn't hurt the range but it makes it look brand new, even my griddle comes completely clean. You just spray it on then let it sit for a bit then it wipes clean.
Apr 18, 2010 | Viking 48" 6 Burner, Grill Professional...
How do you access the ignitor wires for the
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range.
Apr 08, 2010 | Viking VGIC485-6G Gas Kitchen Range
Where can I locate the model number on my viking range? (48")
Mine was located to the left of the top burners. Remove the grates covering the burners, remove the 'spill' pans, lift up the surface that held the spill pans and then on the LHS you should see a plate with your units details.
Jan 20, 2010 | Viking 48" 6 Burner, Griddle Professional...
Basically my gas oven is not heating up properly, the temperature is not hot at all, and food is not getting cooked properly
this is a milti burner unit / and sounds like the ignitors or weak / look below the oven door edge for a glow if orange there bad they need to be white hot .. burners may come on but not all the time .. ****
Dec 05, 2009 | Viking 48" 6 Burner, Griddle Professional...
Viking Griddle thermostat issue
replace the hotplate ignitor. you may in the future have simmilar problems with the ovens or broiler, there are 4 ignitors in my unit I have replaced each at lease once. it seems to be a weak link in the design. If you need more information contact c2d6c2 at yahoo
May 27, 2009 | Viking VGSC306-4B Gas Kitchen Range
Viking range top 2 burners won't light
Either the igniters are at fault (which is usually the case when one or two are not working) or the entire oven ignition system needs to be replaced and can be done through Viking themselves whether you want them to replace it or you yourself replace it, you can get the part through them.
Benjamin
Nov 21, 2007 | Viking VGSC366-6B Gas Kitchen Range
Viking VGSC306-4B Gas Kitchen Range Logo
892 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
