Question about Maxtor Hard Drive
Only see's 33gb of 80gb drive
I have an HP d530 sff system & I am installing a Maxtor 80 GB hard drive, but the BIOS will only see 33.5GB.
Have you checked the Jumper block settings. Its possible your drive is being limited by incorrect settings.
Posted on Sep 05, 2009
Try down loading the hard dsk program from seagate/maxtor site, it solved my problem.
http://www.seagate.com/www/en-us/support/downloads/
Posted on Apr 17, 2009
I have a HP Compaq d530 SFF with a 40 G hard drive. I want to upgrade to a hard drive of at least 80 G. Am I able to do this? Like to know also how much more RAM can I add I have 1.5 GBs now..
You can get a maximum of 4GB of ram.
Yes you can also upgrade your drive, probably to a lot larger than 80.
The following is a link to the manual that you can download, in PDF format, that has information on upgrading/adding both memory and hard disks for the HP d530 SFF. It has both diagrams and instructions.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00059123/c00059123.pdf
Go to the "Hardware Upgrades" section.
Feb 11, 2011 | HP Compaq d530 SFF PC Desktop
I have failed to install ethernet driver after
your operating system should detect and install the drivers for your network controller if it is an internal on board LAN. however you must be sure that you have the LAN enabled in your BIOS setup under the advanced selection on the bios screen. otherwise , your operating system won't even see that you have a LAN connection.
Mar 01, 2010 | HP Compaq d530 SFF PC Desktop
Windows Xp Setup Problem : "setup cannot access the disk". I have HDD: Maxtor Diamondmax Plus 9 80GB ATA/133 HDD.
try doing a F disk on the hard drive first then format it and make it the active drive and then try installing the xp software. if it has had another operating system say for instance windows ME it will not install on that drive without removing it. You can also go to www.maxtor.com and download their free hard drive tools to see if there is a problem that thier software can fix. the software is for free.
Jan 06, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
I want change my hp compaq d530 sff pc hard disk 80gb
Just a case of plugging out the old one, and putting the new one in the same way. Then Installing an OS, and ofcourse any applications you require. If you want to change it, But retain your data exactly the way it is, You will need to install the new drive as a slave, Download a 3rd party application, Ie ghost2kpe, And do an exact disk mirror.
Nov 24, 2009 | HP Compaq d530 SFF PC Desktop
D530 sff hard disk & cd drive update error
hi,
you must be do the default setting into BIOS SET UP so that the hardware you add can detect into it...thanks
Nov 22, 2009 | HP Compaq d530 SFF PC Desktop
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
I have installed s new hard drive maxtor 80 GB, the original one
First please check the Master/Slave connector at the connector side of Hard disk and install the jumper to Master or cable slect and if problem persist then you should have to update the Bios
Mar 28, 2009 | Computers & Internet
Finding it difficult to install a second hard drive on hp dc7700
some older sytems don't have the option to add a second hard drive
can you save your files on cd's or travel drive and then install the new hard drive
Jan 16, 2009 | HP RT810UTABA - HP dc7700 small form...
How to install new hard drive
2 choices for you. Get the external to run the game or 2. Add a larger hdd to the system as a slave drive leaving the smaller drive as the master. If you go the 2nd route just make sure you buy a compatible hdd. Hope this helps & please remember to rate my answer.
Dec 28, 2008 | HP Compaq d530 PC Desktop
No booting
The problem is Operating systems are co-dependent on hardware.
If the motherboards, processors, ram, video adapters, etc don't match you would not be able to swap hard drives and expect to boot.
You could try pressing F8 on boot and try to access safemode.
If it does boot into safemode immediately it will want to reactivate windows.(because of all the hardware changes.
If it still can't boot, you may want to put the 80 gig in as slave to the 40gig and ghost the 40 gg hard drive over to the 80.
If you don't want to lose your data on the 80 gig then reboot with an xppro cd and reinstall windows in the same partition overlaying the installation on top of existing windows directory.
the new windows will have to be activated but all data will still be there.
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
Maxtor Hard Drive Logo
124 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
