Question about Pentax DA 50-200mm f/4-5.6 ED Lens
All three projectors are out
I have Zenith 5263rk tv and it has sound, but the projectors heaters are all off; what could cause all three to go out at once?
  • 2,237 Answers
Power supply board.
Posted on Aug 19, 2009
  • 37 Answers
It might be the video source, or the cable you have hooked up to it, be sure you check that the video cables are plugged in correctly and not damaged. its hard to say what else you need to do not knowing what all you have hooked up to the projector
Posted on Jul 12, 2009
  • 22 Answers
Power supply.
Marc Engineer
Posted on Jun 17, 2009
Tv sounds like it turns on but no pic no sound and none of the buttons on the set work but there is static on the screen for a sec. and then it seems to be turned off
You have several bad capacitors in your TV. There are in the deflection side of the board. I think there are three here. And check the vertical section, as there are three bad caps. You will need an ESR meter to find and replace these capacitors. The older Zenith are known for shut down due to weak and bad caps. Hope this clues you into the fix. Thanks for asking and show a few hands of support!
Mar 14, 2011 | Zenith A27A23W 27" TV
Projectore misaligened get three faces of differnt colour
need more info. like, the make and model of projector.
Jul 27, 2009 | Zenith Projector Lamp
Sound but no picture
Suggest replacing tv.
Apr 07, 2009 | GE 13GP344 13" TV
Bought 2 DTT-9900 converter boxes and hooked them to 2 TV's, get signals after playing around with antenna. but after using both TV's to play a dvd (dvd player hook to TV) The sound went down to almost...
Try turning off the converter box when using the DVD player. The zenith have a second sound control on the converter box remote thus you may have to adjust the sound on the tv remote because you are using the dvr. I set the zenith sound level at the highest level and use on the tv remote only to adjust sound. This eliminated a hiss that the sound control on the converter box was causing.
Apr 28, 2008 | Zenith ZN110 Remote Control
PRO 900x died
For all three to go out at the same time with a little click sounds like a thermo switch. Look for button type silver in color and two wires from it. With an ac tester check with power on to see if you get voltage on both sides or at both connections. Naturally one side of your tester has to be grounded to get 110vac reading on either side of the thermo switch. I f power only on one side you have a bad switch.
Jan 07, 2008 | Zenith Pro 900X Multimedia Projector
Three colors line up on some spots but not others
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 06, 2008 | Zenith IQB50M90W 50" Rear Projection...
Blueand dark when picture should be yellow and gold bright
Well there are many causes for this. In the back of your tv there are three different color projectors. One red, one green, one blue. One or more of them seems to be out of alignment. They can be adjusted but it is recommended to be done by a professional as there are transformers in the back near that area that create the high voltage current needed to run the color guns.
Sep 15, 2007 | Zenith B32A24Z 32" TV
Zenith rear projection television
need to take the unit to or have a repairman visit for a proper diagnosis. causes for shutdown can be many.
Aug 09, 2007 | Zenith IQB56W10 56" Rear Projection...
Open Questions:
See all Pentax DA 50-200mm f/4-5.6 ED Lens Questions
Cameras Logo
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
