SOURCE: 1987 Chevy Suburban 350 2wd not starting or running right
What size engine do you have in it? And, how many miles on it?? Well, I guess it really doesn't matter. At first thought it sounds like you are experienceing a fuel problem, and changing the throttlebody didn't solve your problem. I would start by looking and checking my fuel delivery system. The fact that you had to spray gas into the throttlebody tells me that fuel is not getting there. I would start with the least expensive thing to fix first. Check your gas filters. These are often , OFTEN, overlooked as a sorce of problems, and are rarely changed and often overlooked, and are the problem alot of the time. If that dosen't cure your problem check your fuel pump. Make sure it is delivering the proper pressure. I would bet your problem would be solved, but if it's not then next I would check the electrical components of your fuel system.
SOURCE: engine wont start without priming with gas first, then runs well
i have the same problem on a 98 jimmy 4.3 4x4.
i replaced the fule pump and have good pressure.
new wiers & coil (good spark) no MIL & no codes.
will only start when primed. it will run & drive all day
with no problems.
but once it has been turned off (warm or cold) i will
have to prime it once again to start it.
i have another engine that was in it before it spun a bearing.
it ran fine so i know all parts are good.
i swaped the mass air flow and throttle body but i still have
to prime it everytime to start it. am i forgetting something?
should i swap out the intake with the injectors?
any help would be sweet. thanks.
SOURCE: how to remove door panel on a 1985 cadillac
Very easy! One tool that will save you a lot of headache and anger can be bought at any auto parts store and looks like this:
You use this tool to pop loose the plastic fastners that are attached to the door panel edges.
But first, remove all screws...remove the door handle cup, pop loose the master door/window stich assmbly, etc. Very simple process....takes less than 10 minutes.
Door Panel
SOURCE: I have a 1996 GMC Jimmy. Fuel pump replaced (new)
yes, there is a relay, probably in the engine compartment battery relay box. If the relay fails, oil pressure will allow the pump to run, so the relay is likely to be your problem.
SOURCE: 1989 mustang gt 5.0 fuel
Was looking at posts and other sites. I take it that some relays are even under seats. Anyway, Apparently the ECU relay and the ECC relay are linked. When properly operating the ECC brain sends a signal to the ECC relay and the ground wire is tan/green. The brain can be throwing the signal and the relay terminals are not receiving the signals, so the relays cannot switch.
Although you have replaced some relays, you need to check your plugins for these 2 relays.
