Question about Lavazza Espresso Point Capsule Machine
Heating element on an lavazza expresso machine
I have a lavazza expresso machine, the red light comes on, the green lights do not, I think it might be the heating element. where would you get this fixed at in the greater cleveland, oh area?
You can call this number they will help you with your problem
1-866-526-6204
Posted on Apr 29, 2009
Green power light only on trevi exclusive
When power is turned on, the coffee selection button should blink during warming up. If it is not blinking then the following i possible:
1- The electronic sensor is bad. It is clamp mounted on the boiler to sense temperature and send message to control board to turn the heating off when it is ready to make espresso. The blinking light will be fixed to display this.
2- The heating element on the boiler is bad and not heating. The electronic sensor cannot relay any temperature as it is.not sensing the heating.
3- The electronic control board is bad and not sensing the temperature.
The machine should be opened up to test the sensor or the neating elements, and replace what is bad..
Aug 31, 2014 | Spidem Trevi Automatic Espresso Machine
Lavazza espresso point gets hot and light come on but nothing happens when I hit the green buttons.
Might sound simple, but If you insert capsule, you only have a certain amount of time to hit button and make one. If you take too long it kinda resets. Has hapened to me.
Jan 23, 2014 | Lavazza Espresso Point Capsule Machine
Lavazza 2100
You could avoid this problem by flashing water out without any capsule in. In anycase is a simple problem, you need to disasemble the machine and remove the head shower and wash it from dry coffee liquid which is blocked all the showers holes.
Jun 22, 2012 | Lavazza Espresso Point Capsule Machine
LAVAZZA EXPRESSO POINT THE RED LIGHT BUTTON KEEPS FLASHING CONSTANLTY, WHEN I MAKE THE COFFEE IT SQUIRTS OUT ALL OVER THE PLACE, IT DOENT HAVE A NICE FLOW LIKE IT USE TO
Causes:1- the 130 deg thermostat is open. 2- working thermostat, 104 deg, defective, allowing temp to rise.3- the machine becomes hot because the water valve is stock open. machine needs to be sealed so not to allow water to boil.Water boils at 100 deg Celsius. 4- valvolino or o-rings are worn out and leaking. You need a repair shop.
Guru
Sep 21, 2011 | Lavazza Espresso Point Capsule Machine
Lavazza coffee machine will not heat up the coffee
For Lavazza A Modo Mio only call 0800 599 9200 -they can help over the phone or if still no solution they will refer you to Lavazza UK who have the answers for AMM.
Feb 05, 2010 | Lavazza Espresso Point Capsule Machine
La Marzocco Expresso g3 how do you reouble
Check the thermostat on the top of the back boiler, if the red pin is up then, make sure that there is water in the boiler then push in pin and turn machine on. Now comes the exciting part we have to find out why the boiler overheated, is it because the elements are damaged or the pressure stat is not working properly.
Nov 05, 2009 | La Marzocco Linea Group 1 Espresso Machine
Lavazza expresso machine
Is the machine blowing fuses? Your electronic keypad, or circuit card may be damaged.
If you need service you can call 781-393-2929
we are an authorized lavazza distributor and repair center.
Jun 02, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
625 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
