LG LWHD1200FR Thru-Wall/Window Air Conditioner
Problem for LG LWHD1200FR Thru-Wall/Window Air Conditioner
Will not start
By drewondike on Apr 15, 2009
my window unit will not start, its an lwhd1200fr 11500 btu lg.its about 2 years old and had not been running for about 8 months since the last time that we used it...when i put it into the window last week all that will work is the timer, the light on the timer goes on,as the numbers,but no power any were else.the reset button on the end of the cord lights up too.i push the button to reset but nothing
Best Solution
posted on Apr 16, 2009
Helpful)
drberry
Rank: Guru
Rating: 92%, 82 votes
circut board has a short by the sounds of the system. This board is located in a box right behind the control panel
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for LG LWHD1200FR Thru-Wall/Window
Questions and Unsolved Problems for LG LWHD1200FR Thru-Wall/Window
Do you recommend LG LWHD1200FR Thru-Wall/Window Air Conditioner?
Answer
Answer
select knob for friedrich heat and air unit switch from heat to air .greensboro,nc27403
Answer
Works fine on cool; on heat it puts out hot air for a minute or two and then gets stuck in a... (More)
Answer
Conia 3 HP, 5 yr old air conditioner/ had split system outdoor unit serviced recently, re-gassed,... (More)
Answer
i have a blueway split a/c model aswh24b4 and would like a users manual , how do i get one?
Answer
portable air con - not cooling properly.. The air con blows out cold air but turns off reasonably... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG LWHD1200FR Thru-Wall/Window...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
