Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Water comes out when trigger is squeeze but wont **** up dirty water
Dirty water wont **** up
  • 61 Answers
A. Is your floor/hose knob in the correct position?
B. Do you have suction at the hose end, when in that position?
C. If you answered yes, no in that order then either your motor (provides the suction) is going bad, or it simply is clogged and needs to be serviced.
Posted on Apr 15, 2009
Hoover troubleshooting
Hi! Try these quick and easy steps to get the water from your hose to spray.
Assemble the hose to the unit.
While holding the hose at an angle towards the ground, pump the trigger about 30 times. Turn the cleaner on then squeeze the trigger for 30 seconds.
If the water is still not dispensing there may be soap residue bulid-up clogging the nozzle/valve. Try soaking the trigger end in warm water for a couple hours, then repeating the steps above.
If the cleaner is still not dispensing from the hose but dispenses from the unit, a replacement hose may be needed. Follow the link below to order a replacement hose for your cleaner. Search Results
Aug 23, 2014 | Hoover F5826-900 SteamVac Upright Wet...
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Trigger pin is stuck or something else is wrong. why is it constantly leaking water as soon as I plug it in?
You will need to provide more information as in the model AquaMate you are using as I can't determine which one by your information. You can also call and speak with a tech. at 800-640-2033.
Rainbow Vacuum Cleaner Systems Repair Center
Mar 28, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I CANT GET MY BISSELL SPOTLIFTER MODEL 1716 TO SPRAY THE SOLUTION.
1) Make sure there is water in the solution tank.
2) Try priming the machine by instructing the consumer to squeeze the trigger
repeatedly for 1 to 2 full minutes. Important: If you cannot
squeeze the trigger all the way in, remove the tank from the back of the
machine and then try squeezing the trigger with the tank removed. There is an
internal valve that could be sticking. By removing the solution tank and squeezing
the trigger, it should break it loose, allowing the trigger to be fully depressed.
3) Make sure the open end of the siphon tube in the solution tank is not pushed into the
side of the tank, covering the end of tube. If it is, push the bend in the
Siphon tube toward the back of the solution tank.
4) Check to see if the siphon tube has become disconnected from the outlet fitting on
the inside of the solution tank. If so, you need to buy a replacement solution tank. Parts
can be found at www.bissell.com
5) Check to see if air comes through the spray tip by repeatedly squeezing the trigger
with solution tank off the unit. If not, spray tip may be clogged. Try and unclog
spray tip with a pin or paper clip.
If still no spray, please check the following:
a) Make sure the solution tank is installed properly.
b) Check to see if black O-ring is present on rear connector to solution tank.
May 28, 2011 | Bissell 1716 Spot Lifter PowerBrush...
Water and solution do not dispense.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wrh
Jun 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
Will not let any water out when i squeeze the water trigger.
Try squeezing the trigger a few times repeatdly. This usually works for me.
Mar 21, 2010 | Bissell Powersteamer 1694 Upright Vacuum
Iam trying to use the upolhstery piece. Iam squeezing the button and no cleaner is coming out. Iam using by hoover steam vac deluxe spin.
Confirm that the hose is correctly connected to the clean water supply. If so, then remove it and, with the trigger operated on the hose, try to blow into the water feed connector. If you cannot pass air, the feed tube in the hose is clogged and must be cleaned (either by running faucet water into the brush end (with trigger pulled) or by using compressed air....
Nov 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Wont extract checked the filter, it isnt up all the way, and took apart and didnt find an obstruction
I assume you are talking about no spray. Check the rod inside the handle, amke sure it is moving up and down when you squeeze the trigger, If it is, is water coming out the bottom of the tank when you push in the valve, if it does, then the reservior asm. ( the tank sits on it) maybe bad and will have to be replaced. If yours has a foam filter on the lid of the dirty water tank, make sure there is a 1/4 or so gap from the top of the filter to the top of the tank lid.
Apr 11, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac with Rinse
The bottom tank is for the dirty water, the top tank, it has a small tank attached to it for the shampoo, clear hot water goes in the bigger tank. Then turn it on, squeeze the trigger as you pull it backwards. It will spray and vacuum up at about the same time.
Mar 05, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
209 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
