Question about Maxent MX-42HPM20 42 in. Plasma HDTV
Settings \How do I convert from antenna to cable. I can't veiw my subscribed cable channels.
  • Annalucy Sep 15, 2007
    help me solve this problem
  • 661 Answers
If the Scart/HDMI connections are connected to the appropriate ports on the TV you just need to press the Ext or AV button sometimes marked with a circle with an arrow pointing out C-> this should then allow you to choose which connection you wish to view.
Posted on Sep 15, 2007
SOURCE:
My Toshiba 36AF43 won't get any channels with converter box or anntenna
  • Connect the antenna to the antenna input of the converter
  • Connect the R-W-Y outputs of the converter to the corresponding inputs on the rear of your Toshiba TV.
  • Turn both units on. You should see a converter menu displayed on the TV screen.
  • Select channel scan on the converter. You should see a progress bar displayed on the TV as channels are detected.
  • Scanning should finish by displaying one of the scanned channels.
Dec 08, 2017 | Toshiba 36AF43 36" TV
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
I need a diagram of how to set up the analog converter box or instructions.
I am posting the instructions of how to set up the analog converter box :-
Hope it will you.
· Things you’ll need:
Analog TV, antenna, two coaxial cable, and converter box
· Instructions:
Step 1
Unplug coaxial cable on the back of TV "antenna in" (RF) port
Step 2
Insert coaxial wire into the "antenna in" on the converter box
Step 3
Use second coaxial wire and plug in the converter box, "out to TV" port. Plug the other end into
“antenna in" on the TV
Step 4
Power on the converter box and TV. Change TV channel to 3 or 4. Follow on screen instruction to
Complete setup.
Step 5
After setup you will begin to see more channels than before with better clarity. Some stations will broadcast two or three channels. Enjoy
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 18, 2009 | Televison & Video
Not receiving HD channels on Trutech set
yes it does,also use an hdtv antenna with the
converter box.you may need an outside hdtv
antenna to pick up all digital channels.
Jul 17, 2009 | Televison & Video
Initial channel search ineffective
If you use a top of set box this may be the problem. The tuner in the set could be bad but that don't happen very often. Some place you have a cable splitter that can go bad. Try anothe set on that cable line if it works ok then it is the set
Mar 13, 2009 | Sanyo DP19648 19 in. LCD TV
HD ready?
It was not a problem. It is just a question. Is it HD ready or not without a converter box or cable?
I will go to a store and ask a tech if you can not answer.
thanks
Jan 14, 2009 | Akai LCT3201TD 32 in. LCD Television
How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Jan 01, 2009 | Televison & Video
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
129 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
