Question about Seagate MOMENTUS 5400.3 (ST9160821AS) SATA Hard Drive
Hard Drive Failure
Hi My Sata seagate internal hard drive went down, it makes a clicking sound and isn't recognized by the compu....I have replaced it with a Toshiba but would like to recover the data on the seagate if it isn't to costly. any solutins? Thanks Frank
  • 6,831 Answers
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Posted on Dec 02, 2010
How do I wake a sleeping hard-drive on my pc
possible hard drive failure, try shutting machine on and off consecutively 10 times, to get running.
good luck
Jan 17, 2016 | Seagate Barracuda 7200 1.5 TB 7200RPM SATA...
I've a Fujitsu MHV2080At like external disk and from some days PC don't recognize Hard disk and this is "dead" , the led's are ok when i connect USB but the head of hard disk don0t...
  1. Serial ATA:  If you have a 3.0 Gbit/sec SATA drive that is not being detected by your 1.5Gb/sec SATA controller, or it causes your system to lock up when connected to a 1.5 Gbit/sec SATA controller, you may need to jumper your 3.0 Gbit/sec SATA drive to the slower speed of 1.5 Gbit/sec for the system to recognize it properly. For further information on changing the jumper setting to slow down your SATA drive's transfer rate, please see Document ID: 193775
    -48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA:  It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used. Please consult Document ID: 196299 for further instructions.
  2. Faulty Hard Drive
    If you have completed the above checks and procedures and the drive is still not properly detected, please attempt to use Seatools for DOS (see the tutorial here) to test the drive.  If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
Sep 19, 2011 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
My hitachi hard drive Hitachi HDT721064SLA380 isn't detected by computer and i can here a sound "tic tic" in the HDD ,Thanks .
Hi Welcome to Fixya!
Your hdd is making that sound mainly because it could already be damaged inside. That is also the reason why it is not being detected by the computer.
Same thing happened to me with my 120gb Seagate Barracuda.
Consider in replacing the hard drive on your computer.
Hope this could help!
Have a great day!
Jun 30, 2011 | Hitachi Deskstar 7K1000.B HDT721064SLA380...
My HDD Seagate Momentus 5400.6 500GB is not recognized by win7. I have connected it like a ex USD HDD, but there is no USB devices in Device manager. The hdd is clicking -1sec click, 0,5sec off. Thanks,...
Hi, it might be a file system error.
You could try removing the hdd from the usb enclosure and connect it directly to your pc via SATA.
(power off both of them before doing so)
If it really is the file system then scan disk should repair it automatically when turning on the pc.
Then if the pc recognizes it you can put it back in the usb enclosure.
Jun 30, 2011 | Seagate Momentus 5400.6 500GB Hard Disk...
Seagate Barracuda 7200.10 250 GB SATA Hard Drive
If you have the SATA power and SATA data cable connected and the drive still isn't working, the drive is bad. Get a replacement.
May 08, 2011 | Seagate Barracuda 7200.10 250 GB SATA Hard...
Hi, I tried to install a new Seagate 500GB HD on my windows XP system, I also used a bridge card to adapt the drive, as my system is IDE, the new Seagate is SATA, no jumpers on this drive. Problem is once...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Feb 25, 2011 | Seagate 500GB SATA HD 720016MBSATA3G 500...
Seagate ST31000528AS 1 TB SATA Hard Drive failure
You need to backup your files due to the failure problem and also you can check the warranty of your hard drive from seagate. If it is still in warranty you can send the Faulty Drive to Seagate and they will replace it with a new one. You can register tour product here and check the warranty.
Thanks for using Fixya.
Feb 02, 2011 | Seagate ST31000528AS 1 TB SATA Hard Drive
New hard drive not recognized on mac pro
OK what you could do is connect up that drive to a PC and format it with NTFS, & then put it on the Apple, it should then "See" the drive.Then you can work on it via the Apple.
Jan 29, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
I have a maxtor 6L080M0 hard drive that has crashed The return code is 7 Is there any way to fix this problem.
If the following determines you have hard drive failure then you may have to purchase a new HD. Follow what is recommended from the manufacturer below. READ EVERYTHING.
According to Seagate the makers of Maxtor, you have a DiamondMax 10 (6L080M0). See below or click here
My internal hard drive may be defective, how can I test it?
Question
My internal hard disk drive may be defective, how can I test it?
How can I determine if the problem is with my system or with the hard drive?
It is necessary to run the SeaTools, SeaTools Enterprise, or SCSIMax diagnostic before contacting Technical Support 1.800.SEAGATE (1.800.732.4283) on an internal drive that may be defective.
Answer
For Seagate or Maxtor (or Quantum) ATA drives:
If this is a Seagate or Maxtor (or Quantum) ATA or SATA drive, please download the SeaTools for DOS diagnostic to test it. If the drive is failing, the tests in SeaTools for DOS will indicate as such.
If the BIOS does not recognize the drive or the drive does not spin please reference Answer ID: 48
The operating system will not recognize a drive that is not formatted and partitioned. If you need help with formatting:
  • Windows 9x and ME reference Answer ID: 3076
  • Windows 2000 Answer ID: 880
  • Windows XP Answer ID: 3361
  • Windows Vista Answer ID: 3844
  • Macintosh Answer ID: 492
    For Seagate SCSI drives:
    Please download the SeaTools Enterprise Edition diagnostic.
    For Maxtor (or Quantum) SCSI drives:
    Please download the SCSIMax diagnostic.
    SeaTools, SeaTools Enterprise, and SCSIMax will test your S.M.A.R.T-compliant ATA, SATA, or SCSI disk drive for media defects, perform a read test, physical head test and ensure the hard drive is functioning correctly.
    If all the tests pass (no trouble found), the problem remains elsewhere in your system. Reconfirm all settings for hard drive jumpers, cables, and ATA, SATA, or SCSI controllers, and disk operating system. Consult your host controller documentation or system manufacturer for assistance with SCSI termination or ATA / SATA controller capabilities.
  • Jul 04, 2008 | Computers & Internet
    Seagate MOMENTUS 5400.3 (ST9160821AS) SATA Hard Drive Logo
    198 people viewed this question
    Top Seagate Computers & Internet Experts
    Computer Links
    terminalcon
    John Anderson
    John Anderson
    Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
