Question about Refrigerators
FRIDGE IS FREEZING EVERYTHING LETTUCE MILK ETC
RM2600 fridge keeps freezing everything. Turned temperature down to lowest setting
  • 1 more comment
  • jennett463 Apr 15, 2009
    The thermostat is a blackplastic dial with graduated white marks. I have it on the second white mark. I see no small wire. I am looking at the front of the fridge.
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    OK. Is the refrigerator running all the time?
    and how old is the unit?
  • Raymond Ramirez
    can you verify if there is a small wire next to the thermostat
kweaver1
  • 3 Answers
SOURCE: AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Posted on Jan 20, 2008
SOURCE: Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Posted on Nov 14, 2008
SOURCE: the fridge part of my fridge freezer keeps freezing everything,
Hello
I have the same problem and have talked to the manufacturer. They said to turn off the appliance for 24 hours then it should be good as new when you switch it back on. Obviously you'll have to find somewhere for your freezer contents. I'm going to try this myself tonight.
Fridge Reboot!
Posted on Feb 06, 2009
  • 8 Answers
SOURCE: FRE196AS frigidaire fridge/freezer - fridge freezes everything!
Hello Nicola,
I suggest you contact Frigidaire in the UK, and explain the problem to them. I have included their website for you to do so. You can even call them. I checked with Frigidaire in the US and Customer Service tells me your fridge should not be failing at this point. Contact Customer Service and tell them how disappointed you are in the product; explain the issue; and insist they offer assistance to repair it. Frigidaire Customer Service here does not want to lose any customers, and that includes you. Be nice, but firm with them. I hope this helps you in some way. Let me know if I can further assist. Just trying to to help. :)
http://www.frigidaire.co.uk/contact.asp
Posted on Feb 20, 2009
  • 40 Answers
SOURCE: fridge keeps freezing everything!
you need a damper door and thermostat asm. the door that allows the cool air in is just staying open that is air from freezer and if open all the time will cause your freezing temp in refrig section you can take some tape and cover 3/4 of the grill where you feel air coming out in the frig section to help slow the air it is in the top left hand corner in the back you will feel air. should get you until you can get a repair man.
Posted on Feb 23, 2009
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
May 10, 2012 | Thetford Norcold RV Cooler/Freezer
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Refridgerator is freezing everything
This is likely a thermostat failure. The thermostat is no longer shutting down the compressor or sensing the temperature wrong. The thermostat is a module inside most modern refrigerators and is a fairly easy fix except for the cramped quarters. You can order the thermostat from an appliance repair store. I suggest getting the service manual while you are at it if you have no experience taking a fridge apart.
Do not damage or bend the sensing tube sharply at any time. Be gentle!
Mar 22, 2010 | Amana Refrigerators
My fridge is freezing things on the top shelf
meaning you have a uncontrolled compressor it run continuously without monitoring the temperature, The Temperature control or Thermo control switch. will switch ON the Comp. untill the preset temp. is obtain then Sw. OFF if the temp is out of preset value.
Jun 07, 2009 | Refrigerators
Fridge keeps freezing everything!
Feb 17, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
